Go to Post "THAT'S NOT SAFE!" "But I'm wearing safety goggles!" - Samheartsrobots [more]
Unread 21-02-2012, 10:46
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Absolute Value of Joystick position
The joysticks I have are somewhat off center slightly so the drive motors are constantly running at like .05 as an example.
This is what I am trying to do below but I think the Abs() function converts it to an Integer. How can I use it on a float (or should I resort to more "or's" in the "if's"
if(abs(J_stick1.GetY()) <= .05 || abs(J_stick2.GetY()) <= .05)
     R_myRobot.Drive(0.0, 0.0);
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 21-02-2012, 10:59
Re: Absolute Value of Joystick position
My copy of K&R says that fabs()* should be part of the C ANSI standard library.
* fabs() = floating point absolute value
Unread 21-02-2012, 12:09
FRC #0539 (Titans)
error: `fabs' undeclared (first use this function)
This is the message I get when trying to use fabs() where i have abs() in the previous post
FRC Team 539
Unread 21-02-2012, 12:12
Sounds like you are missing this:
#include "Math.h"
Unread 21-02-2012, 18:17
FRC #0539 (Titans)
Thanks, I built it and it didn't produce an error. I will have to wait to test in a week because we sealed the bot and we are making an extra bot.
I will see if i can test it on this 1 scrap bot some day before then hopefully.
Thanks,
Davis
FRC Team 539
