Go to Post And people laugh at me when I suggest 14" wheels. - Munchskull [more]
Unread 21-02-2012, 13:44
DPG2013 DPG2013 is offline
FRC #4163
DPG2013 is an unknown quantity at this point
what could be wrong with this code. The robot is not responding
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Team4163 extends SimpleRobot {
* This function is called once each time the robot enters autonomous mode.
Joystick leftStick;
Joystick rightStick;
Jaguar arm;
Jaguar claw;
Jaguar launcher;
RobotDrive drive;
Jaguar launcherOpposite;
boolean constant = true;
double LAUNCH_CONSTANT = 0.5;
public Team4163 () {
leftStick = new Joystick(1);
rightStick = new Joystick(2);
drive = new RobotDrive(1,2);
drive.setInvertedMotor(RobotDrive.MotorType.kFront Left, true);
drive.setInvertedMotor(RobotDrive.MotorType.kFront Right, true);
drive.setInvertedMotor(RobotDrive.MotorType.kRearL eft, true);
drive.setInvertedMotor(RobotDrive.MotorType.kRearR ight, true);
arm = new Jaguar (3);
claw = new Jaguar(4);
launcher = new Jaguar(5);
launcherOpposite = new Jaguar (6);
public void autonomous() {
///This function is called once each time the robot enters operator control.
public void operatorControl() {
drive.setSafetyEnabled(true);
while (isOperatorControl())
drive.tankDrive(leftStick, rightStick);
double z = leftStick.getZ();
while(constant = true)
if (z > 0.5)
launcher.set(LAUNCH_CONSTANT * 2);
launcherOpposite.set(LAUNCH_CONSTANT * -2);
else
launcher.set(LAUNCH_CONSTANT);
launcherOpposite.set(LAUNCH_CONSTANT * -1);
if (rightStick.getRawButton(3)) arm.set(0.5);
else
arm.set(0);
if (rightStick.getRawButton(2))
arm.set(-0.5);
else
arm.set(0);
if (rightStick.getRawButton(1))
claw.set(1);
else
claw.set(0);
When I build the project in Netbeans nothing is wrong with it, but when it is deployed the robot doesn't respond. everything seems to be wired up correctly. The robot sees that there is code in it based on the driverstation but the robot doesn't do any of the controls
Unread 21-02-2012, 14:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: what could be wrong with this code. The robot is not responding
Two comments. My best guess is that you need a sleep() or wait() or whatever the java equivalent is in the body of your while(isOperatorControl()) loop. If the brackets in your post match your robot code, then your launcher code will probably never get run, or will only get run before you disable the robot.
while (isOperatorControl()) <-- as long as you're in operator control, your robot will be in this loop.  It should be responsive to your joysticks though.  You may want to put a wait(0.001) call in (or whatever the java equivalent is) because this thread may be monopolizing the cRio CPU
drive.tankDrive(leftStick, rightStick); <-- this will only get called once, since you're not in a loop at the time you call it.
while(constant = true) <-- if this is java or c++, you need to do constant == true.  As this stands, you're assigning true to constant, and then testing if it is true, which means this loop will never end
if (z > 0.5)
else
else
arm.set(0);
arm.set(-0.5);
else
arm.set(0);
claw.set(1);
else
claw.set(0);
Another thing: Our robot was non-responsive yesterday - it turned out we had a gyro in a non-accumulator port, and using the gyro was causing the robot to crash.
Unread 21-02-2012, 14:17
Scimor5 Scimor5 is offline
AKA: Brett
FRC #4520 (Misfit Toys)
Scimor5 is an unknown quantity at this point
wow..... You seriously need to start tabbing your code and keeping track of all your brackets. Also you use while loops inapropriatly. this loop:
		if (z > 0.5)
		else
never ends or updates driving, and its after this loop
that ends when teleop is over, so its going to run when you dissable teleop and then never get out of it.
Good luck from team 4520
Unread 21-02-2012, 14:44
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Once you clean up the loop issues noted above, you should check why you are inverting 4 motors on a robotDrive instantiated with 2. Typically you would only use kLeft and kRight (or instantiate with 4 controllers) and only invert one
