Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 21-02-2012, 21:25
dictionaria13's Avatar
dictionaria13 dictionaria13 is offline
AKA: Marissa
FRC #3574 (High Tekerz)
dictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to all
Things Learned During Build Season
As a rookie, I know I've learned a ton, not all totally FIRST-related. For example:
I learned that zip ties make effective hair ties,
I learned that I rock at crimping connecters onto wires,
A girl on our team who immigrated from Vietnam about two years ago learned about the kind of strippers you don't use on wires (she turned bright red when a guy on the team demonstrated by dramatically peeling off his sweatshirt).
I know I can't be the only one who's learned stuff like this. Anyone else want to share what's happened to them?
Unread 21-02-2012, 21:47
tsakshaug tsakshaug is offline
FRC #0340
tsakshaug is an unknown quantity at this point
Re: Things Learned During Build Season
As a mentor, I learned that getting changed to second shift at work makes it nearly impossible to work with the team
Enjoy every sandwich. --WZ
Unread 21-02-2012, 22:51
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Always design your robot to include wires and battery mounts. Also, don't give your head programmer 1 day to debug code. What he will do instead is write 40 lines of crap code just to do a unit test, and use the time between regionals to debug.... a very not so good idea.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 22-02-2012, 00:12
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
Take "concept-freeze" day seriously.
Unread 22-02-2012, 00:31
Chomper2013's Avatar
Chomper2013 Chomper2013 is offline
Team 1672 President
AKA: Katie Clarke
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Student
Chomper2013 is on a distinguished road
My team's learned that the most popular question is "Where is the Wago/Measuring Tape/ Punch?"
Unread 22-02-2012, 00:55
Jakester9999 Jakester9999 is offline
FRC #2073
Jakester9999 is on a distinguished road
I would also add, "Where is the 7/16" wrench?". Those will always be your go to wrench for FRC.
Unread 22-02-2012, 03:36
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Or you could down-size to "where's the 3/8ths" shifting to the lighter 10-32 screws and bolts.
This year learned that 3/16" rivets are over-kill. It will be 1/8 next year. and maybe thinner gussets too. Maybe even thinner-walled square tube. Who knows?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 22-02-2012, 10:07
shawnz shawnz is offline
Flamewar Initiator
FRC #0907 (E. Y. Cybernetics)
shawnz will become famous soon enough
We learn this one every year.
Unread 22-02-2012, 10:27
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
As a programmer I learned that ~90% of all problems can be solved with this process: (Rather than guess/check or theoretical fixes)
1. Ping the Robot
2. Check the voltage (under load!!!)
3. Check and keep your documentation ACCURATE
4. Walk through your logic with sample data. Then have someone else walk through a psuedocode version. Numbers should match
5. If something works, save and create a backup
6. Sockets, Threading and Vision can be difficult. Split the work up
7. Use the debugger. Its there for a reason.
8. Read the output from netconsole or serial during startup. You can find many hidden errors there, such as defaulting to old code!
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 22-02-2012, 10:46
TheAthlete TheAthlete is offline
AKA: Adam Talajkowski
FRC #0930 (Mukwonago B.E.A.R.s - Building Extremely Awesome Robots)
Team Role: Electrical
TheAthlete is an unknown quantity at this point
Being an electrical lead for the first time, and now the official head driver, I now understand what 'real' stress is. I've only had 2 practice matches at a mini-regional (Sussex, WI) and a total of 30 minutes of pure driving. Now we've bagged and i won't be driving again until competition.
Needless to say, give your drive-team more time with the robot!
And I'm not even the Human Player
Unread 22-02-2012, 10:51
I learned that it's wrong to assume that poor decisions leading directly to difficult situations last year would not be repeated this year.
I learned that a pair of student programmers can do great things without supervision.
I learned that many people are unable to follow simple and explicit written directions, to answer simple direct questions, or to describe simple status indicators accurately. I have to learn that anew every year.
Unread 22-02-2012, 11:24
AKA: noops
Sounds like it was a rough year.... :\
Unread 22-02-2012, 11:27
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Measure twice, punch then drill once - and that people tend to ignore this when under stress
Unread 22-02-2012, 13:36
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Smile Re: Things Learned During Build Season
I was out of it for three years, and come back into it, most things stay the same.
Whatever your team number is, that's how many designs you seem to go through and you still end up modifying it. (i.e. Design 1610, Version 7.)
That even students that are tag alongs or just there can be sucked into it.
Stopping for a meal break and sitting round a table with your team just goes to to show you Family is what you make it.
Decide where you want you electronics board EARLY so you don't have to redo it.
If you make your own frame (ex: Extruded Aluminum) Order it ahead of time so you don't loose a week.
That sometimes even when your behind or ahead, you can be the opposite.
And that you never get FIRST out of your blood.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 22-02-2012, 00:32
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
Originally Posted by Wing View Post
[D]on't give your head programmer 1 day to debug code. What he will do instead is write 40 lines of crap code just to do a unit test, and use the time between regionals to debug.... a very not so good idea.
A better one: Finish the robot early so that the programmers have time to PROGRAM. Seriously, we need time to write and, more importantly, to test our code. My two years so far were awful because of this, and year three likely will be stressful again.
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
