Go to Post If you guys ever need anything, just let us know. Just remember you have the FIRST family behind you.<3 - hayleybayley217 [more]
Unread 27-02-2012, 11:34
lauraleeane's Avatar
lauraleeane lauraleeane is offline
Co-Captain
FRC #0771 (SWAT)
lauraleeane is an unknown quantity at this point
Banebot Gearbox no longer working
Just before bag, one of our banebot 775 16:1 gearbox stopped working. The motor is still working but the gearbox shaft is no longer spinning. We didn't have time to take off the gearbox to address the problem. Does anyone know what is wrong so we can go into competition knowing what to fix? Thanks
Unread 27-02-2012, 11:39
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: Banebot Gearbox no longer working
I'm thinking it might be something along the lines of the pinon on the motor isn't quite on the output shaft.
Regardless of the problem I recommend you order a new gearbox and motor assembly and just swap them when you get to competition. After that you can take apart the gearbox you took off and figure out the issue knowing that you can play.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 27-02-2012, 11:49
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
The pinion has probably slipped on the motor shaft. It happened to one of our 775's during practice this past weekend.
At a minimum, you'll want to order a couple of extra pinions from Banebots. They're only a couple of dollars each, and they ship the pinions out quick, usually only takes a couple of days to get them.
The old pinion is most likely wallowed out and ruined. Hopefully the motor shaft isn't galled up and you can just press on a new pinion.
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 27-02-2012, 12:42
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Did you grease your gearboxes before assembling? Ungreased gearboxes can quickly turn into metal glitter.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-02-2012, 12:47
Steps for using banebots gearboxes:
1: Grease your internals and assemble
2: Run your gearbox for about 15-20 minutes. Or in 10 minute periods
3: Disassemble
4: Clean
5: Re-grease but do NOT overgrease. White lithium may be a little too thick so I usually just scoop some grease from FP gearboxes and drop it into the banebots gearboxes.
6: You should be good to go
Gear dust + thick grease without going through this process will bind up your 16:1 gearbox.
Unread 27-02-2012, 12:55
Co-Captain
FRC #0771 (SWAT)
3: Disassemble
4: Clean
Is it bad that I am using white lithium grease? It's the only grease my team has. And do we need to disassemble the gearbox so often?
Unread 27-02-2012, 13:03
Use it in moderation. You only need to take it apart twice. Once to do the first application of grease then again after you break them in and have to clean/regrease.
Unread 01-03-2012, 10:13
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
When I grease the BaneBots, I actually will run them for about 45 minutes after greasing. I start with a low voltage and gradually increase it until the motor runs steadily at 12 volts with about 1-1.5 mA.
Note: if at first the motor has trouble starting to rotate, try manually spinning it with some force to get it started.
As for number of runs, depending on the gearbox ratio, run the motor about 2-3 times.
Hope this helps.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 01-03-2012, 13:39
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Get your hands on some LocTite 603 "green" Retaining compound. Use a Q-tip to coat the inside of the pinion gear before pressing it on. You have to install the pinion quickly and in one step otherwise the compound will cure and lock the pinion in place part-way through your install making it impossible to press it further onto the shaft. Be very careful to use it sparingly and do not get any on the motor's bushings. One of my teams' sponsor is a snowmobile repair and recycling company and most snowmobile (2-stroke) crankshafts are made in multiple pieces all pressed together hand held purely by interfereance. This compound is used with each press fit to lock the components together. It will not release unless it is heated. It is an excellent product and I use it religiously on interfereance fits.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 01-03-2012, 13:56
Co-Captain
FRC #0771 (SWAT)
Do you have any tips on pressing on a pinion gear as we don't have a machine press. We put on the other one with a hot plate and hammer.
Unread 01-03-2012, 14:37
pfreivald's Avatar
AKA: Patrick Freivald
That might be part of your problem... A bent shaft or misaligned pinion can wreak all kinds of havoc on a gearbox.
Ask local machine shops -- someone is bound to have a press that either you can use, or they will use on your behalf.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
