Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
Unread 28-02-2012, 09:24
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Robot Tyco Drummer?
I recently had a challenge proposed by a friend in our school's tyco drumming club: a tyco robot! Any ideas or examples?
I was intrigued by how controlled and quick the arms (assuming it was a slightly humanoid robot) would have to be, and the mechanism for holding the sticks would be complicated as well. It would have to be able to hold the sticks somewhat loosely I think in order to drum properly.
As for programming, I think it would be cool to just be able to input drum beats and have it play them!
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 28-02-2012, 09:28
Andrew Lawrence
Posts: n/a
Re: Robot Tyco Drummer?
You gotta think a little outside the humanoid thing. Maybe instead of arms, it has a few pneumatic cylinders over the drums that extend and retract to hit the drum and play it. Not only would it be fast, but you'll get a pretty repeatable sound each time, and it's much simpler than any arm you'd need to build.
Unread 28-02-2012, 09:31
dbeckwith's Avatar
Lead Programmer
That would be simpler certainly, but I was thinking it would be cooler to have a humanoid one, not to mention more of a challenge.
q = (2*b) | ~(2*b);
Unread 28-02-2012, 09:37
Andrew Lawrence
Posts: n/a
True, but then you have to deal with encoders, more sensors, and more variables. A suggestion of mine is to look at Team Titanium's Guitar Hero Robot, and see how it used pneumatics to play guitar hero, but still looks like a human.
Unread 28-02-2012, 16:37
dbeckwith's Avatar
Lead Programmer
WOW! That's an awesome robot!
q = (2*b) | ~(2*b);
Unread 28-02-2012, 17:04
ThaineP
Posts: n/a
A taiko drummer robot would be pretty cool. Will it have to play alongside humans and in time?
Unread 28-02-2012, 17:39
dbeckwith's Avatar
Lead Programmer
I didn't intend for that, but that could be an added functionality. It could "listen" to the other drummers and attempt to keep the same tempo!
q = (2*b) | ~(2*b);
Unread 28-02-2012, 17:52
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
I would recommend using moving the drum sticks in the same manner as the 'fingers' on the Guitar Hero 'bot. I don't think you'll need a flexible mount (as long as you properly tune the maximum position of the drumstick), but you could use some sort of rubber mount for the drumstick(s) to get some flex.
It doesn't look to me like it uses pneumatics to me, I see electromagnetic solenoids.
Jason
