Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 05-03-2012, 21:06
Best Available Data
FRC #1778 (Chill Out!)
What did it take to win a Week 1 Rebound Rumble match?
"I'm not looking for the best players -- I'm looking for the right ones." -Herb Brooks, Coach US 1980 Olympic Hockey Team
Week 2 gets to play the game that Week 1 gets to figure out. What a week it was! Below is some analysis that I hope will help you as you get ready to rumble this week.
Included is all Week 1 regionals (Israel not included), and events (MAR & FIM). This includes 676 qualifying matches. First up, a boxplot of scores, divided into winning/tying alliances and losing/tying alliances. Winning and losing in this piece always mean winning/tying and losing/tying, as it was mildly easier to do that than throw out all of the ties. (4% of matches ended in a tie)
A couple of key observations. Winning alliances tend to score a lot more points than losing ones -- since alliances are fairly randomly selected, some biasing factor (hint: think endgame!) likely seperates them. Winning alliances scored on average 22 points per match, whereas losing ones scored 8.7. That is, the winning alliance had to only balance one robot to win the average match last week!
Next up are the distributions of winning and losing scores. I find it interesting that while winning alliance scores are fairly normal, losing alliance scores are significantly skewed.
Basically, this drives home the point that teams did not need to score many points to win matches. Less than 5% of losing alliances scored more than 25 points!
Winning alliances tended to do better, but the mean was still 22 as mentioned above.
Adding to the two together, you can see the distribution for total alliance scores, which had a mean of 15.4 as others have mentioned.
A couple of parting thoughs based on these
1) Give yourself plenty of time to balance the bridges! I can't tell you how many points scored this weekend were bridge points because I haven't gotten a parsed copy of the twitter feed yet, but scores are so low that they can't have been an overwhelming proportion. Watching the webcasts lots of teams appeared to shortchange themselves, but I think for most robots time spent balancing the bridge is better spent than time chasing after balls.
2) Teams are not scoring a lot of points. If you miss a ball, it takes a long time to chase after it. Only take shots you are sure of. Again watching webcasts, it seemed like most teams were not playing defense in qualifying matches -- use this to your advantage! coughFENDERcough
3) Don't overreach! Set a simple, robust strategy and follow it. In line with #2, I think a defender going back and forth along the fender will be a big obstacle for a lot of teams.
Unread 05-03-2012, 21:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: What did it take to win a Week 1 Rebound Rumble match?
From my experience at San Diego being able to balance on a bridge is not usually a matter of time...it's something that is difficult or impossible to do at all for many teams.
Unread 05-03-2012, 21:32
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Do you have any guesses as to why they couldn't balance? Was it a lack of specialty hardware to aid in balancing, or was it a driver practice/communication problem.
Unread 05-03-2012, 21:45
MrForbes's Avatar
AKA: Jim
First you have to get the bridge down. That is a significant challenge for many teams (it took us two days at the regional to get our bridge arm to work reliably). Getting on the bridge is easier if there aren't any balls in the way...which there are about half the time, it seems, since when you first lower the bridge the balls roll right in the way. Then you have to be able to drive the robot slowly enough and with enough control that it can balance. The kit drive train is a bit fast for doing this, and also most robots roll a bit after you let go of the joystick. This is assuming you were able to get on the bridge straight, and didn't fall off the side.
We found a whole bunch of ways to fail at getting on the bridge and balancing. Fortunately our shooting made up for it, but many (most) teams don't have that to fall back on.
Unread 05-03-2012, 21:42
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
My experience was quite the opposite. In KC I could get almost anyone on a bridge. Sometimes their appendage was too weak for them to get on by themselves, but almost every drivetrain could follow me up the bridge for a co-op attempt.
We did have some difficulty with Jags set to coast instead of break. Teams had trouble keeping their drive train from sliding around the bridge as it tipped back to level in coast. Many younger teams did not fully understand the difference.
We saw drive trains with six pneumatic wheels, 2 friction and 2 omni, swerve, mechanum, even 4 mechanum with 2 omni. They could all balance with the right partner and someone to give them some pre-match coaching.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 05-03-2012, 21:48
MrForbes's Avatar
AKA: Jim
That seems to be a big part of it....if you are with a team that is good on the bridge, and both teams work together well, then it's usually doable. That's pretty common in eliminations, but not so much in qualifying. My guess is we'll see a wide variation in regionals.
Unread 06-03-2012, 02:15
waialua359's Avatar
Happy Birthday! waialua359 waialua359 is offline
AKA: Glenn
FRC #0359 (Hawaiian Kids)
This makes perfect sense.
You know what your team can do, but imagine if it was vice versa?
Without mentioning specific teams, I saw it to be just the case in eliminations......where the widebot was waiting at the end of the bridge for their partner to balance with them on the bridge. It failed when they needed it the most, and was the difference between advancing vs. being eliminated.
Unread 06-03-2012, 03:10
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
From my experience at Hatboro-Horsham (which, granted, now seems to be one of the best events of week 1), it was rare that teams weren't attempting to get on a bridge during a match. Balls under bridges caused many failures, especially if teams didn't leave time to cross the bump or couldn't cross the bump. Many other teams, including 1712, didn't have functioning bridge manipulators and had to follow up other teams.
Because of this, 1712 only once tried to balance on our own alliances' bridge during qualifications (we tipped with 1 second remaining), but had seven attempts at balancing on the co-opertition bridge (three successful, two where the other team never went for the bridge, and twice where we "failed"/ran out of time). Without the ability to manipulate the bridge ourselves, we figured the best way to ensure QPs was the co-op bridge with a balancing machine from the other alliance. The 4 coop points we had at the end of Friday were a big portion of why we were seeded 5th at the time. Some bad luck on Saturday and other teams starting to use the co-op bridge more led to us falling to 13th, but the concept was proven.
Our bridge manipulator should be functioning and durable by Lenape, so we'll see if our strategy changes.
Unread 06-03-2012, 08:33
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
I guess my comment stems from the title more so than the presented data. A QS of 22 seemed on average to be good enough for 1st or 2nd seed. As I see it during qualification rounds there are 20 opportunities to get 2 points. 11/20 doesn't seem that great to me. The point being that winning is not everything as the tournament structure is different this year.
Unread 06-03-2012, 08:44
Jaxom Jaxom is offline
AKA: Michael Hartwig
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
KC only had 9 matches, so our average may be a bit higher than it appears from raw numbers. As for the average -- I don't think a lot of teams thought through the scoring system enough, and didn't realize that coopertition points would be so important, win or lose. I don't like having them so important, but they are what they are. I think this will change dramatically in the coming weeks, and 22 will soon not be enough to get you in the top 10.
Mentor http://www.teamtitanium.org/
Unread 06-03-2012, 12:40
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I only looked at SMR data, but 45 of the 81 qualifying matches were decided by 10 points or less, so without a lot of detailed review that would imply the ability to balance at least one robot would be very beneficial. Many matches the winning score was <10, so either alliance balancing just one robot could have won that match. In 28 of the 45, at least one alliance had less than 10 points, so a single balance could have changed the outcome.
From the matches I watched, I think a key was to be flexible. Many matches just needed one robot to balance to win, but alliances were trying for 2 and then ended with o.
It would be interesting to look at all the match data from week 1 and see the "margin" trend.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-03-2012, 13:52
Best Available Data
Ask and you shall recieve. I'm still waiting on someone to parse the FRCFMS twitter feed for me, as the margins we care most about are the ones where the alliance had the opportunity to make up the difference. That is, if you lose by 10 points but already balanced two robots you couldn't have done more.
25% of matches were decided by less than 5 points, 50% by less than 10, 75% by less than 19, and 90% by 30.
Unread 06-03-2012, 15:13
Ask and I shall receive eh.. well it would be nice if data was separated by elims and quals. I imagine this request may be too difficult though.
Unread 06-03-2012, 15:28
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I would be interested to know what the winning score data without bridges is. Ie, how many baskets do you need to make to get a chance of winning?
-Plutarch
Unread 06-03-2012, 15:35
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
All of the data he has posted so far was just qualification matches.
