How is qualifaction score calculated?
Also what is HP, BP, and CP?
Re: How is qualifaction score calculated?
Im pretty sure, HP: Hybrid Points; BP: Bridge Points; CP: Coopertition Points. That was the same question i had last week.
![]() Oh ya, and Qualification Points are calculated like this. If a team wins a match they get 2 Qualification Points. If a team balances on the coopertition bridge with an opponent, all teams on both alliances receive 2 Qualification Points. ![]() Last edited by EagleEngineer : 09-03-2012 at 18:25. |
You get two qualification points when your alliance wins, one in the event of a tie and two coopetition points when the coopetition bridge is balanced with at least one robot from each alliance. Your alliance gets 1 coopetition point for trying to balance the center bridge, defined as the bridge supporting a robot from each alliance, but not being balanced. Your coopetition score is added to your qualification score to produce the final qualification score.
posted wrong link. here are the correct ones:
http://frc-manual.usfirst.org/viewItem/58#5.3 Qual scoring: Para 5.3.3 HP BP TP CP explanation: Para 5.3.4 & 5.3.6 |
HP=Hybrid Points
BP=Bridge Points CP=Coopertition Points Here's the simple math to figure it out: Qualification Score (QS) = Wins*2+Ties+CP |
