Go to Post You can take the man out of FIRST, but you can't take FIRST out of the man. - George1902 [more]
Unread 12-03-2012, 13:35
Ninjabot513 Ninjabot513 is offline
FRC #2383 (Ninjineers)
Ninjabot513 is an unknown quantity at this point
Camera Targeting Code/Dashboard
Hi, team 2383 (The Ninjineers) here, and we are using Labview and having some issues incorporating rectangular target processing.vi into our main framework so that we can take the distance from that process and throw it onto our dashboard. We also use the M1101 camera. If any teams have any advice on doing any of the above functions please post a reply, and if you have code that has been made already it would be a great help if you'd post it or email it to rsalafia@live.com
Unread 13-03-2012, 00:18
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Re: Camera Targeting Code/Dashboard
We have functioning code to process the image and return the distance, all on the dashboard. I will post a universal version to help you out.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
Unread 13-03-2012, 00:35
Alumni
AKA: David Donahue
http://dl.dropbox.com/u/42324681/Distance%20Get.zip
here is the code. It should recognize the target, and return the distance. It is very reliable, and doesn't take up valuable processing power on the cRIO. If you need to send info to the RIO, I can help you with UDP. hope this helps
Unread 13-03-2012, 12:51
Thanks a bunch! Well go ahead and test it at our next meeting. If we have any issues I'll post them thanks again!
