Non-Classmate Will not wirelessly connect
I have try almost everything I could possibly think of to get our non-classmate laptop to connect to the robot so our team can run it.
The Driverstation on the classmate still connects and runs fine, and From the non-Classmate laptop we can still run the robot from wired connection. Is there anyone out there that can provide some help? |
Re: Non-Classmate Will not wirelessly connect
Dumb questions first
:Did you make sure your wireless card is on/enabled? Is your wireless card set to a proper static IP? |
Yes I have set up the new laptop and fixed all the IP's to be correct. I do get an error saying watch dog not fed but that is only on the new laptop not the classmate
When you say "will not wirelessly connect", what exactly do you mean? Where in the process is it breaking? Is the laptop unable to see the robot's wireless network? Does it show an error when you tell it to connect to the network (which I assume is named "522")? Does it successfully establish the wireless connection but not show communication with the robot?
Tell us in detail what you are doing, and what you expect to happen, and what happens instead. |
Ok ill try... The problem is when I try to connect the new non classmate laptop to the d-link router currently hooked up to the cRio it will connect and disconnect repeatedly. All the Ip's are set up correctly and i folowed the FIRST manual to the letter on how to connect a non-classmate laptop to the robot.
I expect the non-classmate laptop to function like the classmate but it currently is not. But the network is seen and the connection is excellent. |
I still don't know what you mean by that, especially when you follow it with "the connection is excellent." Help me out here -- just tell me what I would see happening if I watched over your shoulder. Don't try to interpret it for me. Don't try to use words other than those showing on the screen. Don't distill it down into a simpler description. Just report the facts and let me apply my knowledge of the system to try to form a theory of why it's not working the way you want it to.
#7
Ok...I turn the robot on and double click the icon on the dekstop to open the driver station program. The connection light on the left goes green for a few seconds then it goes red and repeats this many times. When the same is done on the classmate laptop, the connection light holds a steady green and i can operate the robot using the joysticks.
#8
When you say "connection light", do you mean the "Communications" indicator on the Driver Station screen?
It sounds like you might have a firewall program on the computer preventing it from communicating with the robot. Make sure you've turned that off. |
#9
yes the communications light, i Turned off all firewalls and virus protection programs and still the same problem
#10
Do you have the classmate laptop and the non-classmate laptop running the Driver Station software at the same time?
What is the IP settings for your non-classmate laptop? |
#11
Both are not running at the same time and the ip on the non classmate laptop is 10.5.22.6
