Limit Switches???
ok so I've used team 358s example on a toggle switch and it works great except what i want the toggle to do is run a motor until a limit switch is pressed, but if the toggle is hit again reverse the same motor, looking for a different limit switch and stop.
At first I thought that it was the limit switches, because for some reason labview is reading normally open switches as true, but in programming as the values were easy to reverse it still wasnt reading my limit switches. What might be the reason?? Help!!!!!!!!!!!!! |
Re: Limit Switches???
Ok so ive realized that the limit switches aren't being ignored the only problem is that they have to be held down and then the toggle must be activated again to stop the motor I'm so confused
I assume you are using either a state machine or a parallel task to do this? You'll probably get useful answers faster if you post your code. See attachment. The boxes are states, the arrows are events which cause the state to change. You might want to add additional events to allow the toggle switch to cycle through all the states. Last edited by Ether : 17-03-2012 at 16:01. Reason: added block diagram |
Describing your setup as well would probably help.
In pseudocode, it would be something like: Code:
direction = forward
toggle_prev = false
loop:
if report_state(limit_switch_1):
stop(motor)
direction = backward
if report_state(limit_switch_2):
stop(motor)
direction = forward
if report_state(toggle) != toggle_prev:
if report_state(limit_switch_1) or report_state(limit_switch_2):
set(motor, direction)
## Keep in mind this will only work if set() is a state function
## (that is, if set() doesn't have to be looped to keep the motor running())
elif report_state(motor) == running:
stop(motor)
toggle_prev = report_state(toggle)
delay 100
