Go to Post Why aren't the kids who sit alongside the sidelines and observe as valued? Why are they looked upon as leeches, in it for a trip? - Madison [more]
Go Back   Chief Delphi > Other > VEX
Unread 17-03-2012, 15:29
code009 code009 is offline
None #1234
code009 is an unknown quantity at this point
Question controlling robot speed in RC mode
Hi!!
I am new to Vex Robot programming. We have a competition coming up in our school where we are supposed to run our robot in RC-mode on a racing track and complete the lap in less than three minutes. We are using easy-C for programming our robot. I am having some trouble in handling the robot as one of our motor module runs faster than the other. I was wondering if there was any way to control the speed through some programming code,etc. to make both the motor modules work at the same speed?!?!
Thanks!!
Unread 17-03-2012, 16:49
alancop's Avatar
alancop alancop is offline
200mph club member
AKA: Alan Copeland
FRC #1716 (Redbird Robotics)
Team Role: Electrical
alancop is an unknown quantity at this point
Re: controlling robot speed in RC mode
Look into using VEX encoders, they send you data about exactly how fast a motor is running, then you can use that data to tell the motors to run at the same speed verses running at an ambiguous value.
Unread 17-03-2012, 17:17
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
If your motors are running at significantly different speeds, it's good to look for mechanical answers first.
1. Are the motors the same type? If they are high strength motors, do they have the same internal gearing?
2. Is there significant friction on one side, or an imbalanced load? Try picking up the robot and running the motors "in air" to see what the speeds on each side look like.
You can program the motors to run at different levels of R/C sensitivity, but this is more difficult than balancing mechanically.
Are you using EasyCv2 (for PIC) or EasyCv4 (for Cortex)?
In v4, the "stop" position is 0, with 127 at full CW and - 127 at full reverse. If you want to slow down one of the motors, you can store the input from a joystick (say 2) to a variable, then scale it.
In pseudocode:
declare constant Gain = 0.8 (or any number between 0 and 1)
declare variable Ch2input, Ch2power
while (1==1)
Ch2input = GetJoystick(2)
Ch2power= Gain*Ch2input
Setmotor(2,Ch2power) //Motor port 2
end while
For v2, you do something similar, but you have to subtract off 127 before scaling, then add it back on before setting the motor, because the "stop" motor position is at 127. Also in V2, use GetRxInput, rather than GetJoystick.
You'll need to use floating point (not integers), because gain< 1.
Lastly, there's a lot more Vex-related traffic on Vexforum.com, so you might get more/faster answers there.
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 17-03-2012, 23:31
None #1234
Thanks a lot that was very helpful!
