Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
Unread 21-03-2012, 20:37
Blazanax's Avatar
Blazanax Blazanax is offline
FRC #2443
Blazanax is an unknown quantity at this point
File Size Compression
So, the maximum file has to be no more than 50 MB. Well, let's just say our animation is pushing the limits a little bit right now. By about five times.
How should we go about slimming down the file size? Even if the animation is only 30 seconds, 50 MB for an HD video is a pretty tight restriction, so I'm sure other animation teams must have a few tricks up their sleeves. If you would, please, care to spare a newbie animator a tip or two?
Unread 21-03-2012, 20:43
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: File Size Compression
I'm not on the animation team, however the animator on my team said his .avi file was 5 GB's, then after compressing it it became 50 MB or so. Try compressing it.
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 21-03-2012, 21:00
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Likewise, I have not done any animation, but have spent time with videos.
The software you are using is probably outputting/exporting to a high definition lossless format. You may want to see if you can reconfigure the settings to a lower quality and try again. there are also a lot of video converters on th internet that will compress or lower the resolution for you. Just note that as you decrease the file size you will lose some crispness and clarity. However, I have found that most people can't tell (other than the creator(s)).
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 29-03-2012, 13:35
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Just to remind you, the files must be Quicktime .mov with either H.264 codec or MPEG-4 - not .avi. We reduced ours down to 47MB by choosing H.264 and limit the kbytes/sec. It is a tight squeeze.
