Crazy robot idea for this year 2
the first idea was not circulated much but it was a 3 ball shooter on segway like chassis that could fit on the bridge with any two other robots and would flop over once power is cut.
how ever the second idea is if you made a flying ball that had about an 18" diameter with bumpers on it that could do to things; fly to opponents end and sit in oppomnents 3 point basket, fly to bridge and hover while touching an alliance robot for 30 seconds and then fall and roll to the ground at the end of the match. http://www.atomicrobotics.com/2011/10/flying-ball/ would this be legal? would this be a game changer? I am looking at rules now. can't find rule that says you aren't allowed to be above the opponents fender or touching rims. they assumed this would not be possible with the 14" arm and 60" height limit. Plus I haven't seen anything about what is considered a balance if after game play your robot falls off bridge. 1 battery (or super capcitor if allowed to replace) 1 CIM, 3 small control motors froma quad copter rig, 1 victor, 1 quad copter control board (unless CRIO has to be used), 1 wirless controller, 1 circuit breaker, 1 light, 1 wireless adpter and walla you have a single rotor helicopter self contained that just has to fly for 1 minute with that weight If CRIO has to be used does the crio have to be on the robot? can it be on the control board and connect to a secondary wireless RC like control system? Specifically i would be looking for anyway to offload weight from the required "large FRC" components. Just a thought. Good night |
Re: Crazy robot idea for this year 2
Fun ideas...however, they're fraught with peril.
For the first one, if it falls over while on the bridge, doesn't that risk unbalancing it due to the centre of gravity shifting? Check out the 5 second rule, [G37]. For the second, among many other potential issues, you will need to deal with having the battery, the cRIO and other heavy things onboard to be considered a robot. Also, how will you avoid unsafe operation? |
the 5 second rule. Doh.... then it would nee to land. as long as partner has flat spot with whole in it to land on we are good. |
In some ways no different, but different in one crucial respect: it's a lot harder to protect the scorer's table and the front row of spectators. A control issue on a regular robot rarely leads to a departure from the playing field; that's hard to guarantee on a flying robot. And because it's above the field barrier, disablement doesn't mitigate the threat nearly as well. (Plus, as determined by the required parts, it would have to weigh a minimum of around 20 lb—that's a lot of momentum to arrest.)
This has been discussed. Flying is illegal because it is impossible to keep your bumpers in the bumper zone. Bumpers must be in the zone during normal operation, and if flying is normal, you need them there while flying.
In addition, no part of your robot may extend more than 60" off the ground- wait. Only when in contact with the other alliance's carpet. So you're good on that front. EDIT: I stand corrected. The bumpers need only be in the Bumpers Zone while the robot is standing on a flat floor. See post below. Last edited by remulasce : 06-04-2012 at 04:00. |
I stand corrected. The required battery + crio, combined with the limited set of motors, are more than enough to make this impossible in my view, but if you can do it, I think the "safety" rule is the only thing standing in your way. Which would also be near-impossible to satisfy, but you may try as you like.
#8
This years set of motors has one of the highest power densities I have seen in FIRST. If you ran all of the 550s (all 8) into a single gearbox (low reduction, high speed), and put a large prop on it, you could get some substantial lift. Motor power breakdown: -AndyMark motors (AM- 0912)> 180.83W * 2 = 361.66W (current is below limit) -Banebots RS-550-120-------> 253.52W * 4 = 1014.08W **(slightly less due to current limits, at this power level, they draw 43.2 amps each) -Fisher Price 00801-0673-----> 291.59W * 2 = 583.18W **(prob. not quite this high, this would require 54.76 amps per motor) ----> this comes out to 1958.92 Watts, theoretically. So, How much would that be able to lift? (more specifically, how much would that be able to lift using a propeller?) |
#9
And I've seen a case where the same prop tested at two different thrust levels in two different locations. Not fun trying to figure out why...I suspect it had something to do with either the air density or a mounting change, or both. |
#10
Does anyone have performance data from 2009 for similarly sized propellers? |
#11
Don't get caught up in the details with props and their inefficiencies, sizes, etc. Do the broadest, most basic calculation possible to check and see if it is within the realm of feasibility.
If we take a minimum robot mass (25lbs) and use the entire cross sectional area of the robot envelop, 28inX38in we find that we will need to generate approximately 0.0235psi (162Pa) of dynamic pressure just to 'hover' in free air, ignoring ground effects. Pdynamic = ( fluid density * fluid velocity^2)/2 fluid density = 1.18kg/m^2 (~STP) Pdynamic = 162Pa Fluid Velocity => 16.9m/s Total air flow rate is 28in*38in*16.9m/s = 11.6m^3/s In a basic sense we need enough power to accelerate 11.6m^3 of air to 16.9m/s in 1s. This can be simplified to a basic energy problem: Air mass = 11.6m^3*1.18kg/m^3 = 13.7kg air velocity = 16.9m/s Air's kinetic energy = 1/2*mass*velocity^2 = 1950Joules Time available to apply this energy = 1s Total power required by this method = 1950J/1s = 1950W to maintain hover, including no inefficiencies. This is about what PAR_WIG1350 figured that eight motors, drawing well over 280A, could produce. It is technically unfeasible with our legal battery. It is technically unfeasible with our required main breaker. Even if these barriers were removed, the motors would not last long at peak power. |
#12
A giant Helium balloon would off set the weight. Is that legal?
#14
The helium itself would be legal, unless in a hazardous state. |
#15
For something as heavy as a typical FRC robot, the required helium-carrying device will most likely have a hard time fitting in the field, if not the venue. Trust me on this. For something like a 18" sphere, with bumpers and battery, you could probably fit said helium-carrying device into the field if you didn't max-weight the robot. However, maneuverability would be highly limited due to rules about leaving the field boundary. |
