Go to Post You shouldn't have to apologize at all for wanting to have fun. This is supposed to be fun. You shouldn't gauge your level of enjoyment at the event based on your place in the standings. - Koko Ed [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 07-04-2012, 23:37
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Serial To Jaguar PCB
Hi All,
Attached is a screenshot of a project I'm working on in Altium (by the way, does anyone else use that, particularly because of the FRC license?).
This PCB is meant to convert the DB9 plug on the cRIO to a 6P6C RJ11/12 port, with termination across so that the CAN bus works.
I personally do not enjoy making those plastic converters, and would rather a PCB, I have an old revision made in EAGLE on the robot (and it worked), and I can post a picture of that later.
Let me know what you think,
Oliver
Name:	Black-Jag Bridge Board.png
Unread 08-04-2012, 19:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Serial To Jaguar PCB
Originally Posted by linuxboy View Post
Hi All,
Oliver
Good idea, but not a good design in my opinion.
You would have a heck of a time getting the screw that holds the serial port to the cRIO screwed in.
Rotate the RJ-12 port to be in straight in line with the RS-232 port.
My $0.02.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-04-2012, 01:13
I'm confused. What need is this supposed to fill? If it's just something to plug into the cRIO's serial port and provide a way to connect a Jaguar, a perfectly useful connector was included in the Kit of Parts.
Unread 09-04-2012, 01:30
This looks like a great introduction to PCB design!
I agree with Ryan, re-arranging the connectors might make life easier. You should be able to export the 3D model of the circuit board to something Solidworks or Inventor understands - try modeling the screws and the tool paths in one of those and re-work the design from a ergonomics/usability angle.
Unread 09-04-2012, 19:22
AKA: Oliver Graff
FRC #3780
Hi,
Sorry for the long response time.
Eric & Ryan, I will rearrange that! the reason I minimized it was for price. The one we used on the robot this year did have room for screws, I just didn't have any screws and it worked fine, didn't pop out at any point, although, when designing a product I would want it to work with screws.
Alan:
I have had issues with those plastic things (although that may have just been due to the supplier), either way, I trust using a PCB a bit more than wires, while, when made correctly, I think the plastic connectors work fine, soldering a resistor to wires inside a plastic case, just seems like bad practice to me, and I think this may be more reliable.
Unread 10-04-2012, 16:14
AKA: Oliver Graff
FRC #3780
Attached is a modified board, same footprint, what do you guys think?
Name:	REV. C Connectors.png
ID:	12570  Click image for larger version
Name:	Rev. C Back.png
Unread 11-04-2012, 01:07
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
I'll order a half dozen.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 11-04-2012, 02:19
AKA: Oliver Graff
FRC #3780
Awesome .
If anyone is interested in a prototype, PM me so we can discuss details, since I haven't settled on a final design, and I'll want to talk to each person getting a prototype. I will (hopefully) have a couple boards of some revision with me at champs.
- Oliver
Unread 11-04-2012, 14:10
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
This looks really great!
You'll be in full production by the end of the week right?
Unread 11-04-2012, 14:47
I'd be interested in one. You might also want to talk to our Altium sponsors, give them the warm fuzzy feeling of knowing their donation was helpful.
For whatever reason, DB connectors are always a purchasing nightmare, especially with high pincounts (25,37). For something that purports to be a standard, there sure are a lot of variations. If you intend to support this design long term, assume that the specific part number you order today won't be available tomorrow. With that in mind, leave a little extra room to fit the replacement part. It looks like your design has plenty, but keep it in mind if you make a housing.
Unread 11-04-2012, 16:38
AKA: Oliver Graff
FRC #3780
Wellll, the Altium license is non-commercial so I don't know if I can produce and sell the devices, does anyone know?
Eric, will you be at champs? If not, I can probably mail you one, or I can just send you the gerbers or the altium project if that is easier for you. I do intend to eventually have this be something many teams can use year to year, once I figure out licensing and a supplier. (Anybody interested?) In terms of letting Altium know I'm making use of the donation, would I do that at champs, or should I email someone?
- Oliver
