Go to Post No one ever said that this was easy. - Jaine Perotti [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 23-04-2012, 04:20
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
URGENT: CAN Jag error code 1 - dequeue element in acquire semaphore
Hey all,
I am trying to inalize code for championships. My team leaves later today (Monday), and our shooter, which was working earlier, now will not. I am running CAN on it, speed control with an encoder.
I know the electronics are right, as it will run properly in a different project. But in my LabVIEW project containing our actual drive code, I get this:
"error code 1:
Dequeue element in acquire semaphore.vi:1->WPI_CAJaguar_SetTransaction.vi:28->WPI_MotorControlSetOutput.vi:9->Periodic Tasks.vi->Robot Main."
I would post my code, but I'm typing this post from my phone as our build site has no Internet access.
What I can tell you is that the jag runs perfectly fine with what I believe to be identical code in a different project. It is the only jag in the circuit, firmware 101, off the can bus, we are not using 2CAN.
It is output to in periodic tasks, on a 20ms delay. I can't figure out what the problem could be, and I only have a vague idea of what the error actually is. I understand the concept of a semaphore, but I don't know where I should or shouldn't be setting one.
Any help would be much appreciated, I only have today to get this working before we leave for St. Louis.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
Unread 23-04-2012, 10:46
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
Re: URGENT: CAN Jag error code 1 - dequeue element in acquire semaphore
Originally Posted by legogeek24 View Post
Hey all,
I get this:
"error code 1:
Note: Labview isn't my forte but ...
The error message to me implies that your code is accessing something that wasn't properly initialized, probably the CANJaguar controller. I'll take a quick look at the WPI_CANJaguar_SetTransaction vi and see if I can get a sense of what could have gone wrong. The CAN bus uses messages to update the Jaguars. The message are queued and dequeued and I suspect a semaphore is used to protect access to the queue.
Took a quick look at the vi, and it was as I suspected, it tries to acquire the semaphore, and then sends the command. The semaphore is part of the CANJaguar reference that is passed in. I would suspect that the CANJaguar reference is bad in some way. Without seeing the project that fails, I'm not sure what else to tell you.
