Thread Tools |
Rating:
Display Modes |
Source for Shaft Couplers
Does anyone have a good source for inexpensive shaft couplers? I'm looking to couple a 1/4" od encoder to the end of a 1/4" od shaft for the steering portion of a swerve module. Both shafts will be smooth, no flat spots, so I'm looking for a clamp style (not set screw style) shaft coupling. To allow for some manufacturing tolerances I don't want it to be completely rigid, so I was looking at using a semi-flexible slit type coupling like this.
At $13.50 the SDP/SI plastic version is the cheapest version I could find. Aluminum versions all seem to be $25-30. Any comments on plastic vs aluminum? Automation direct makes some (here) for $7 but they're setup for 6mm shafts. Does anyone have experience with these - do they work for 1/4" shafts, do they require modifications, etc? Since we'll be buying several of these I'm trying to find the most economical option that will still be reliable. Any suggestions are greatly appreciated. Thanks. |
Re: Source for Shaft Couplers
While not very pretty, we often couple encoders to shafts using surgical tubing that is zip-tied into place. It works quite well.
I've never looked at the cost while ordering these at work, but the company we always go to is Ruland.
http://www.ruland.com/index.asp |
http://www.mcmaster.com/#standard-sh...plings/=hh6zib
There are a variety of shaft couplings here and you can specify which bore sizes you want. |
Same here.
We do the same. We got the idea from Dan Katanski from team 240.
#7
In addition, that also is good for dealing with misaligned holes. Trust me, it happens.
#8
Anyone have a picture of how they use the surgical tubing to connect an encoder to a shaft?
#10
http://www.chiefdelphi.com/forums/sh...74&postcount=7 http://www.chiefdelphi.com/forums/sh...7&postcount=25 |
#11
Nothing to see here... ![]() |
#12
As you probably realize, the encoders depend on the shaft bearings to keep the encoder disc aligned. Surgical tube will not do that.
#13
I've never seen the Surgical tubing method used with KOP encoders, only US Digital S4 series encoders. Though, You could take a 1/4" Pin and slide it into the KOP encoder and then attach surgical tubing to that... Not sure how to address the disk alignment issue though. |
#14
-John |
#15
We've used these on our 2011 and 2012 robot for our arms/turrets.
http://www.mcmaster.com/#9658T3 -RC |
