Go to Post If people are getting offended at seeing other teams list their accomplishments, maybe they should spend less time whining and more time doing things to make their own team win. - artdutra04 [more]
Unread 18-05-2012, 12:44
TeacherWeeks TeacherWeeks is offline
FRC #3706
TeacherWeeks is an unknown quantity at this point
Motor Controller Testing
I was wondering if anyone had devised a good way of testing motor controllers? If so I'd love to know your method, my team has a couple of controllers that are questionable and we need to test them.
Unread 18-05-2012, 16:59
Re: Motor Controller Testing
What type?
Unread 18-05-2012, 17:40
You can build your own test rig. All you need is an old unwanted junker laptop and a couple of motors. (And a battery).
Take the laptop and install FreeDOS on it.
Write a simple app to toggle the RTS pin on the serial port to simulate the desired servo signal (you can code it to simulate both Vic and Jag signals). You can get highly accurate and stable performance because there's no multitasking going on. You can hard-code a test sequence into the app, or you can read the test sequence from a text-file script, or you can have a simple user interface to change the command.
Build a fixture to hold 2 motors with their output shafts connected together. Drive one motor with the motor controller you are testing. Run tests with the leads of the other motor open. Stop the test and connect the leads together and run another test with the leads shorted.
Unread 18-05-2012, 20:04
DonRotolo's Avatar
Back to humble
FRC #0832
You can also attach a motor, a battery, and build this. No computer needed.
Unread 18-05-2012, 21:38
That looks like a fun project !
The date of your post is 11/05...
Has anyone has built one of these lately? Where did you get the parts and what was the total cost?
Unread 19-05-2012, 00:56
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
We have something similar, courtesy of our electrical mentor. Unfortunately, I haven't had the time to become familiar with the circuit itself, so I can't provide many details.
Parts were salvaged from his inventory as a hobbyist; I believe total cost was in the $20 range.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 19-05-2012, 01:53
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Here is ours. We use a y pwm cable to the Jags to test ganged motors. We use this device to test our prototypes, motor burn in and robot builds before the electronics go in. All the parts were from Radio Shack under $50
http://www.youtube.com/watch?v=ibuAAnxgExQ
https://picasaweb.google.com/1045493...18593684294434
http://www.youtube.com/watch?v=t-Tius1e10U
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-05-2012, 04:24
sretter's Avatar
sretter sretter is offline
AKA: Shaked
FRC #2231 (OnyxTronix)
sretter is on a distinguished road
Hi, is there any chance that you/one of your teammates could explain a little about how you built it?
(I've seen it before and got excited, but I'm not exactly sure how to implement one ourselves)
Anyways nice idea!
Unread 19-05-2012, 07:49
Gdeaver Gdeaver is offline
FRC #1640
Pololu has several RC servo controllers.
http://www.pololu.com/catalog/category/12
I use one hooked to a lap top to run our motors when the C-rio and the programers are not available. Also can do analog conversions to check sensors. The app that runs on the pc is nice.
Unread 19-05-2012, 14:01
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Jameco has a tutorial about PWM:
http://www.jameco.com/Jameco/workshop/diy/pwm.html
http://www.dprg.org/tutorials/2005-11a/index.html
https://www.jameco.com/webapp/wcs/st...0001_120539_-1
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-05-2012, 16:41
sretter's Avatar
AKA: Shaked
Awesome thanks!
Unread 20-05-2012, 09:10
DonRotolo's Avatar
Back to humble
FRC #0832
Parts are Radio Shack, cost was about $15 including a nice little case. Can be less fancy if you have a good junkbox.
Originally Posted by PAR_WIG1350 View Post
Why do you need a dual timer? Most circuit I have seen use a 555.
One timer generates the pulses every x milliseconds, the other varies the output pulse width from 1 to 2 mSec. If you try to do both with a single timer you end up varying a parameter you don't want to vary. Plus, a 556 is really no more expensive than a 555...
Unread 18-05-2012, 23:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
