Go to Post The best parts of FIRST just cannot be described. They have to be experienced. - sanddrag [more]
Unread 29-05-2012, 13:18
RoastBeefer RoastBeefer is offline
FRC #3055
RoastBeefer is an unknown quantity at this point
Netbeans FTP
Hello, whenever we try uploading code it takes 4-5 minutes. The longest part of running the code is here:
Network interfaces on host:
    Broadcom NetXtreme 57xx Gigabit Controller:  address: 10.30.55.5 netmask: 255.0.0.0 <--- on robot's subnet
Connecting FTP @10.30.55.2
upgrade:
Sending local file image.suite
Where it says Connecting FTP@10.30.55.2 it takes about 4 minutes every time to continue. Everything else is super fast. Is there anything we can do to make this faster?
Unread 29-05-2012, 13:21
FRC #3055
Re: Netbeans FTP
This is the entire output in case you need it:
init:
init:
Deleting directory C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\build
Deleting directory C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\suite
Deleting directory C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\j2meclasses
clean:
Created dir: C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\build
Compiling 1 source file to C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\build
compile:
Created dir: C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\j2meclasses
preverify:
Created dir: C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\suite
Building jar: C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\suite\duurrrhurr_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 158 classes and generated 4 files.
Expanding: C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\suite\duurrrhurr_1.0.0.jar into C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\suite
Moving 1 file to C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\suite
Deleting: C:\Users\Developer\Documents\NetBeansProjects\duurrrhurr\image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) Client VM 22.1-b02
Target IP: 10.30.55.2
upgrade:
flashapp:
deploy:
init:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
   Waiting for cRIO to reboot (8s)
   Waiting for cRIO to reboot (9s)
   Waiting for cRIO to reboot (10s)
   Waiting for cRIO to reboot (11s)
[cRIO]
[cRIO] -> * Loading debug.o: debug
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO] Copyright 1984-2006  Wind River Systems, Inc.
[cRIO]
[cRIO]              CPU: MPC5200 -- Wind River Lite5200 BSP.
[cRIO]     Runtime Name: VxWorks
[cRIO]  Runtime Version: 6.3
[cRIO]      BSP version: 2.0/10
[cRIO]          Created: May 27 2011, 11:02:24
[cRIO] ED&R Policy Mode: Deployed
[cRIO]    WDB Comm Type: WDB_COMM_END
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] * Loading nisysrpc.out: nisysrpc
[cRIO] * Loading NiRioRpc.out: NiRioRpc
[cRIO] * Loading nivissvc.out: nivissvc
[cRIO] * Loading nivision.out: nivision
[cRIO] NI-RIO Server 4.0.0b8 started successfully.
[cRIO] task 0xe15f38 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading visa32.out: visa32
[cRIO] * Loading niserial.out: niserial
[cRIO] * Loading NiFpgaLv.out: NiFpgaLv
[cRIO] * Loading FRC_FPGA.out: FRC_FPGA
[cRIO] * Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication was compiled from SVN revision 2923
[cRIO] FPGA Hardware GUID: 0xA14C11BDE4BB64AEF6A86FC52A294CD9
[cRIO] FPGA Software GUID: 0xA14C11BDE4BB64AEF6A86FC52A294CD9
[cRIO] FPGA Hardware Version: 2012
[cRIO] FPGA Software Version: 2012
[cRIO] FPGA Hardware Revision: 1.6.4
[cRIO] FPGA Software Revision: 1.6.4
[cRIO] * Loading FRC_JavaVM.out: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2012 FRC, Jan  5 2012, 17:20:48
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 11.0rc14
[cRIO] task 0xdc23c0 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Nov  5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] DIO LoopTiming: 260, expecting: 261
[cRIO] Default IterativeRobot.disabledInit() method... Overload me!
[cRIO] Default IterativeRobot.disabledPeriodic() method... Overload me!
[cRIO] Default IterativeRobot.disabledContinuous() method... Overload me!
[cRIO] Robot Drive... Output not updated often enough.
[cRIO] Default IterativeRobot.teleopInit() method... Overload me!
[cRIO] Default IterativeRobot.teleopContinuous() method... Overload me!
