Go to Post Don’t choose to aim for the stars because they mark the peak of our abilities, don’t choose to aim for the stars because it is easy, choose to aim for the stars because it shows the depth of our potential; choose to aim for the stars because it is hard! - Ken Leung [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:31
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
WARNING...Dr. Joe's advice on the drill shaft is incomplete!
Posted by nuts4first.
Engineer on team #340, GRR - Greater Rochester Robotics, from Churchville-Chili and Nortel Networks.
Posted on 3/22/2000 10:13 PM MST
F L A S H B U L L E T I N
If you have taken Dr. Joe's advice by producting a replacement drill gearbox output shaft as described in 'Dr. Joes Drill Advice' step # 5 and as seen in the drawing 'Dr. Joes Drill Shaft' (in the lower right hand corner) be warned!
The drawing is missing a critical cut at the aft end of the shaft, in the middle of the 4 pins. If you are using this technique in your robot's drive system be cautious. A ~
[IMG] code is Off
Q&A Discuss: Dr. Joe's Advice Work on new Boschs? CD47-Bot Extra Discussion 1 06-01-2003 22:18
Dr. Joe's Advice Work on new Boschs? Ryan Curry Motors 1 06-01-2003 12:30
WARNING...Dr. Joe's advice on the drill shaft is incomplete! archiver 2000 5 23-06-2002 22:31
Shafting size, keyways, and Dr. Joe's Drill Shaft Alan Ing Technical Discussion 7 04-12-2001 10:30
