Go to Post Is it legal? Yes. Is it Graciously Professional? Yes. Is it smart? No. - dlavery [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 31-07-2012, 04:34
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Lightening Pattern Help?
What is the most idea form for lightening two-speed transmission gear boxes
and a West Coast Drive Belly Pan? I see that teams (254/973) have the diamond shape design, but I am not sure how to do it myself using Solidworks. I have been informed that the minimum strut length for the aluminum is 1/8 inch. Can somebody please offer me technical help?
Thank you.
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 31-07-2012, 10:07
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: Lightening Pattern Help?
For the belly pan youn should be able to just make one diamond and then use linear sketch patern to copy it
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 31-07-2012, 10:13
Thank you.
You can check out 973's CAD right here on CD for the bellypan. There's links in Adam's signature. I don't have the dimensions on me at the moment. As for the gearbox, I think the webbing looks approximately 1/4" thick but this is just a guess, better to check out their CAD and ask questions from the source!
Unread 01-08-2012, 00:12
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
It's been a while since I've used SolidWorks (you use Inventor when you intern at Autodesk I guess), so this may not be the most efficient way.
Bellypan:
I make four holes in the corner of the bellypan - two triangles and two squares - and then use patterns and mirrors to complete the entire cheese hole pattern. If I want to and holes/extra webbing for gearbox cutouts/electronics, I go back and make them separately by cutting away the material I don't want and then extruding the shapes I do want back in.
Gearbox:
With a gearbox it's just a slow process of outlining the areas that will remain (around bearings, spacers, bolt holes, etc.), followed by adding in the lines that will connect them. Attached is a picture of the drawing I created for the lightening pattern I used for a gearbox project I've been working on. Notice how I used fairly few dimensions for the amount of sketch geometry. I did this by using a lot of sketch constraints, ultimately making the sketch easy to use if I ever want to go back and make changes.
Hope this helped, I'd gladly try to answer other questions.
Name:	Gearbox Lightening.jpg
Website
Facebook
Unread 01-08-2012, 20:01
Design Mentor
Originally Posted by IanW View Post
Gearbox:
Yes, that definitely helped. Here is the final gearbox that I've designed.
Name:	Final Gearbox.JPG
Unread 01-08-2012, 20:04
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You should fillet all of the inside corners. If these are plates that will be milled, try to design them use the largest end mill that is reasonable. If it's water/laser cut, you'll still want to add fillets to make the cuts faster and cleaner and to reduce stress concentrations at the corners.
--Madison--
...down at the Ozdust!
Unread 01-08-2012, 20:11
R.C.'s Avatar
Happy Birthday! R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Agreed,
Also put a little support between your shifter/bearing block square to the bottom of the plate.
-RC
R.C.
MadTown Robotics Team 1323
Unread 01-08-2012, 21:33
Design Mentor
Originally Posted by R.C. View Post
Agreed,
-RC
Thanks to the both of you. I have updated the gearbox. Is there anything else that you can see that should be improved upon/changed/added?
Unread 02-08-2012, 03:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
What purpose does the inner snap ring groove serve on the output shaft?
2001-2004: Team 100
2006-Present: Team 254
Unread 09-08-2012, 10:36
Design Mentor
Sorry about the late response. The inner Snap ring is designed to hold the other side of the wheel in place. I added this feature to the output shaft to ensure that the wheel would be held in place. If I were to take it out, what would prevent the wheel from sliding inwards?
Unread 09-08-2012, 10:55
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
just wondering: did u stress test these plates, including for collisions that may be less then ideal?
edit: o, and did u example the irl ability to travel to ensure the gears stay where u want and don't generate undesired interactions?
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 09-08-2012, 14:42
Cory's Avatar
AKA: Cory McBride
is this for a standard cantilevered wheel drivetrain?
If so, your wheel is captured by your bearing block in the outside of the frame rail.
If not, add a spacer. Your shaft is all but 100% guaranteed to fail at that snap ring as it stands.
There's no need to perform FEA on those plates. By visual inspection they look similar to multiple other successful gearboxes. 1/4" Aluminum plate is ridiculously strong, even pocketed out like that.
2001-2004: Team 100
