Go to Post The holiday season is formally known as "kick-off rendering season" - dlavery [more]
Unread 11-08-2012, 19:19
3666's Avatar
3666 3666 is offline
FRC #3666 (Bolton Bear Bots)
3666 is an unknown quantity at this point
Values through Dashboard
I was wondering if it is possible to update values through the dashboard. Like changing the value of a motor through a input box.
Unread 11-08-2012, 19:58
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Values through Dashboard
Yea, it is possible. You can make a button on a the dashboard, then UDP send that data to the cRio. And somewhere in your robot code, place a UDP receive loop to receive that data so you can use it in your code.
Search "UDP" on CD and many helpful threads should come up. They may be talkng about send UDP from the robot to the dashboard. But its the same the other way around.
Edit: Here's a good example http://www.chiefdelphi.com/forums/sh...28&postcount=4
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 11-08-2012, 20:33
3666's Avatar
How exactly would I make an value input box on the dashboard?
Unread 11-08-2012, 21:24
androb4's Avatar
AKA: Andrew A.
Make a new Dasboard Project in LabView and add all necessary inputs in the front panel of the Dashboard Main.vi
