Coefficient of Friction Testing
I just published a post which highlights my method for calculating the coefficient of friction for robotic drivetrain systems.
So this brings up my next question... Who actually bothers to do this? Does anyone? Is it just me? Does your team have their own method? Does your team just trust the manufacturer's specs? Do you even care, or do you just say "this is grippy as heck" and not bother? Please share. Originally posted here. Last edited by JVN : 11-08-2012 at 22:56. |
Re: Coefficient of Friction Testing
Our team did calculate the COF on the wheels as I was having an argument with one of the mentors regarding the number of motors to use. Personally, I just used one wheel for the test.
Which wheels? What was your result?
These wheels were 29635T31 from McMasterCarr. The argument was whether or not these would slip; if they did slip, a second motor in the gearbox would be useless. I do not have the results as they were written in someone's journal; I do not believe he/she still has it. Sorry for the relatively pointless post.
Years ago we did some friction testing on 968, but it was far from scientific. Our primary goal was to determine how much of a role wheel width played on friction with regards to maximum pushing force. In the past, 968 had run rather skinny wheels (as skinny as 5/8" tread width). We made up two sets of wheels with tread (and I don't remember if it was wedgetop or roughtop). One set was 1 inch wide, and the other set was 1.5 inches wide. We installed the narrower wheels and filled a plastic container with batteries so it was quite heavy and experimented with having the robot push this container on carpet. We then added more weight until the robot could no longer move it. We then swapped out the wheels for 1.5" wide ones and gave it another go. The robot pushed it with no problem, and it took adding something like another 40lbs to the container to make it un-moveable again.
While not very scientific, we did determine that wheel width can play a substantial role in friction. Beyond that, the only thing I really bother to do each year is press some wheels against the ground while simulating turning them and think to myself "yeah, this grips well." I know, not very 'engineer' of me. If the need arises in the coming season, perhaps I'll have some students do the test you describe. |
Wow, never thought I'd see this brought up.
Some years ago, we actually had to find the COF between a rough-ish sponge and a piece of wooden board (relatively smooth), for a physics lab. My group promptly used the method you've detailed, and why not, it's so dang easy. However, our results were not what we expected. We saw huge variances in the "sliding" angles. We're talking +/- 20 degrees here. We never did figure out what were causing the variances. The teacher provided a whole host of possible reasons, none of which really did the problem any justice. The most common/successful method was probably to weigh down the rough surface and then use a force gauge that provided a force vs. time reading. Then, from rest, slowly pull. At a certain point, the rough surface+weights will start moving. At that same point, your force will peak, and that becomes the maximum static friction (Fs). From there, it's a simple Fs = Fn * mu calculation. Granted this did require more technical equipment, it also seemed to provide much more consistent results. - Sunny G. |
#7
We found that the tilt test is much more consistent for FRC applications as described. -John |
#8
We don't do this routinely (being both somewhat limited and somewhat naive in wheel choices), but with the bridge this year we did several true experiments, including using the full robot and bridge with various wheels and other surface texture changes. We used both tipping and dragging (as our CG meant tipping sometimes preceded slipping). With all our off-season drivetrains, we're setting up weighted testbed chassis and switching in wheels/treads on carpet, polcarbonate and polypropylene (approximation for polyethylene).
Weighing down the surface (higher but constant normal force) gets you past some of that initial "noise". However, beware both the "pull slowly" difficultly JVN describes and the failure of Columbian models when contact area isn't proportional to normal force (below saturation) and/or frictional force isn't proportional to normal force (independent of contact area). |
#9
-John |
#10
Generally the published results were fairly reflective of our results, but we ended up with more noise than I was expecting, for which we couldn't find any real trend or explanation. We also found that the blue nitrile wore better and handled dust, etc better than the roughtop. (No numbers--a reflection that's reminded me to belatedly add wear testing to our summer procedure.) Colsons are somewhat better on the bridge, but by the time we did the switch we were using our real robot (CG around ~15") and we always tipped before falling* -- at well over the bridge's maximum angle. We haven't done much wedgetop testing yet--on the summer list.
*EDIT: Do'h. Absolutely need to point out that this test was conducted with our pivots at 45deg angles. Wow. My bad. /...\ \ ../ Last edited by Siri : 13-08-2012 at 15:56. |
#11
Why do you want to know the COF of your robot?*
*Are you sure you are asking the right question? Very cool post. I have used a similar method for estimating COF of material on material. The tilt test is also a pretty good way of testing CG location, but it can get tricky. |
#12
Nothing against those that do, we just inevitably run into bigger problems that eat up our time during the time it's a relevant question. (After all, the system is different next year.) |
#14
John,
We don't calculate the CoF. If we need to know, we test relative to some other standard (i.e., another robot) by pushing it along carpet and measuring force - sometimes with 'calibrated legs' only. Your method is valid for static friction, but dynamic friction is also important IMHO, since once you start moving the value is usually quite different from static friction (= Sticktion). To measure that in your test setup, you lift to just below your normal angle, set the robot sliding, then reduce the angle to where it stops. This was very important to us in Lunacy, for example, where the wheels were generally not at rest relative to the surface. Probably the 'interlocking' of the soft, rough sponge with the smooth-but-not-as-smooth-as-you-think wood. Get a particularly strong splinter of wood, and it grips more than if you only get weak (or short) ones. |
#15
That is, do you have the same coefficient of friction with a tire sliding at 1 ft/s as you do with a tire sliding at 10 ft/s. |
