Go to Post Mentors may not be the direct focus of FIRST, but they are just as involved as students are. They play a pivotal role in the success of FIRST and of the success of every team. - Dan Petrovic [more]
Unread 02-09-2012, 14:26
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
pic: FRC488 First Sheet Metal Drive
Unread 02-09-2012, 14:27
Re: pic: FRC488 First Sheet Metal Drive
What gauge sheet is that? Looks slightly thinner than .090" to me. Is that a custom shifter or SS internals?
Looks great as usual, and super light!
Unread 02-09-2012, 14:32
Madison's Avatar
FRC #0488 (Xbot)
I believe it's .090, but I am not certain. Those are regular super shifters with the black housing replaced by spacers; they're just bolted onto the side rails.
It's 34 lbs., but there are lots of places to take out some more weight. A lot of the webbing is thicker than it needs to be, but those are lessons that can come later. I was excited to see that all of the parts fit together in the first place. He did a MUCH better job with this than I did the first time I had to design a drive.
--Madison--
...down at the Ozdust!
Unread 04-09-2012, 10:06
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Looks very good!
You should look into getting rivets with the correct grip range, the ones you're using appear to be a biiiiit too long.
-John
Unread 04-09-2012, 11:03
protoserge's Avatar
protoserge protoserge is online now
AKA: Some call me... Tim?
Very cool!
What is the spacing you chose for the standard mounting holes?
Have you considered using 0.063" if you have access to it?
Unread 04-09-2012, 11:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Looks great.
Unread 04-09-2012, 18:22
Rahul Bhardwaj's Avatar
Rahul Bhardwaj Rahul Bhardwaj is offline
FRC #0488 (Xbot)
Team Role: Driver
Rahul Bhardwaj is an unknown quantity at this point
THANKS! It's actually .0625'' aluminum The grip range is off by quite a bit since someone at our hardware store grabbed from the wrong bin (to be fair the one we ordered was longer than we needed anyway) but we decided to just go with it.
Rahul Bhardwaj
Team Xbot 488
Unread 04-09-2012, 19:30
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Definitely would be a good idea to make the spacing between the cut outs smaller, for reference I usually do 0.75" spacing, but now for parts of the plate that have nothing mounted on it I am most likely going to do 0.5".
I'm not sure why, but I always seem to make the chassis plates higher than the wheels, just to enclose them, I kinda like that it wasn't done here, a lot of weight was saved there, maybe I will do the same next time.
This also looks like a smaller wheel, I think 6" (if those are 8inch wheels that I'm looking at) could also work on this chassis. Not sure If that was planned for them to be interchangeable? But If it is interchangeable (even if it wasn't designed to), and you seem to have a hard time turning sometimes, you could increase the torque by putting smaller wheels on there.
Oh MY! Is that a designed battery box I see there!! WOW! Thats Luxury right there... Prop's to the student for remembering to design that in. After designing our whole robot myself this year, and the off season chassis, that's the thing I forgot Both times...
Over All Great chassis, hope that students knows how well of a job he/she did
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 05-09-2012, 02:42
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Just wanted to say this drive train looks fantastic, and has inspired me to finally start work on another concept of mine!
Thanks!
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 05-09-2012, 07:37
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
In my opinion, the most important part of the original post is this,
"We've been working with a new sponsor over the summer that brings sheet metal fabrication resources to our team."- Madison
This is a prime example of how to build team strength.
New Sponsor
working over the summer
new resource to the team
They may or may not be asking for money of the sponsor, but instead they have found something that might be more important. During the summer, they are working out the file transfer and formatting. They are getting a feel for the quality of work the suppplier can offer. They are also working on building a new line of communication. Many of us wait until the stresses of build season to try this out. It is easy then to allow those stresses to turn into pointing fingers rather than working through communication or timing issues.
Bravo 488 on a great project. Most of us could replace "sheet metal" with plastic molding, or shaft turning, or CNC bracket or ...
Unread 05-09-2012, 07:40
Thanks!
- Andrew
Oh god. You DON'T Need to design ANOTHER Chassis.
2013-Present
2010-2013
Unread 05-09-2012, 17:45
Bob Steele's Avatar
AKA: Bob Steele
Great work Madison!!
Are you able to bend the aluminum or are you attaching the flat pieces using angle between them?
Our chassis is built very similarly utilizing angle aluminum and a jig one of our mentors came up with to hold the pieces rigidly at 90 degrees...pretty slick
congrats to the designer and fabricators!!
Unread 05-09-2012, 18:31
Madison's Avatar
FRC #0488 (Xbot)
The parts are were all bent on CNC breaks at the sponsor's shop. When the parts come in, we just rivet it together and it's good to go.
--Madison--
Unread 06-09-2012, 00:06
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is online now
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
This is gorgeous. Can I have one?
Congrats on the new connections and having the opportunity to "work out the bugs" before you put one of these bad boys on the field.
Definitely looking forward to see what comes of this in a few months.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
