Go to Post Sometimes simplicity is the best feature you can show off. - Koko Ed [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:44
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
weak link which probaly plagued many Bots
Posted by Bob Drexel.
Engineer on team #358, Titans, from Hauppauge and Festo Corp..
Posted on 4/10/2000 8:36 PM MST
Just a note to all on our findings, which I suspect gave intermittent problems to many. Our problem was typical, inconsistent jerky motion with poor control of key drives (i.e. drive wheels). Well, after hours of trouble shooting our robot (took four rounds to finally solve it), the culprit was the thermal breaker mounting base. If you pop off the plastic cover you’ll find that the breakers are held in place on three extremely small fingers utilizing friction only. These weak fingers are susceptible to bending which compromises the electrical connection and causes excessive resistance. This all leads to thermal buildup and cooked breakers.
After insuring a tight connection to the spade’s of the breaker our intermittent problems were solved (unfortunately to late).
Anyway, we had a great time, (we’re a rookie team) placed 77th in the nationals, learned a lot, and will be back next year!!!!
#0047 (ChiefDelphi)
We were in the same boat
Posted by Keith Liadis.
Student on team #131, C.H.A.O.S., from Manchester Central High School and Osram Sylvania and Fleet Bank.
Posted on 4/16/2000 1:01 PM MST
In Reply to: weak link which probaly plagued many Bots posted by Bob Drexel on 4/10/2000 8:36 PM MST:
I don't know if anyone noticed.. but we had the same problem.. during both the regionals.. and the nationals.. we had this problem numerous times during the matches... Luckily.. we still came out on top... we ended up driving with our traction wheels down.. pushing our high speed wheels which were locked in place
[IMG] code is Off
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
