Using thresholds on WPICameraExtension classes
Hello, This year my team is looking into utilizing camera tracking more than last year. We are using java and I understand the process used for on robot tracking already. Now I am looking into laptop based tracking. I already know how to create a WPI camera extension.
Using some code provided by team 237 I have made some progress. The biggest problem right now comes from thresholding. In there code they have Code:
WPIBinaryImage red = image.getRedChannel().getThreshold(64),
green = image.getGreenChannel().getThreshold(64),
blue = image.getRedChannel().getThreshold(64);
WPIBinaryImage threshold = red.getAnd(green).getAnd(blue);
I was under the impression Thresholds required a range of values. How is each channel only using one value? A location for some sort of API documentation would also be appreciated. |
Re: Using thresholds on WPICameraExtension classes
from WPIGrayscaleImage.java (from the WPIJavaCV project):
* Returns a black and white image where every pixel that is higher (in the 0-255 scale) than the given threshold is <bold>white</bold>,
* and everything below is <bold>black</bold>.
* @param threshold a value 0-255. if a pixel has a value below the theshold, it becomes black
* if the pixel value is above or equal to the threshold, the pixel becomes white
* @return a new {@link WPIBinaryImage} that represents the threshold
public WPIBinaryImage getThreshold(int threshold) {
validateDisposed();
IplImage bin = IplImage.create(image.cvSize(), 8, 1);
cvThreshold(image, bin, threshold, 255, CV_THRESH_BINARY);
return new WPIBinaryImage(bin);
The companion function getThresholdInverted() simply reverses the ranges, and if you compare getThreshold() and getThresholdInverted() from the same image with the same threshold, they should be perfect negatives. |
Thanks for the info. i think I understand how the thresholds work. But I’m not clear on how to isolate a color. I can see using a combination of inverted and normal thresholds to do this. But in my testing I have had very little success. This is partly because im not sure how to combine them. team 237 used a variant of the code below but I don’t see much logic in how this executes.
There is also a .getOr() function which I might be able to use. Code:
WPIBinaryImage threshold = red.getAnd(green).getAnd(blue); on a side note where did you get that code snippet? |
Ok I understand the thresholds now, but I'm still unsure how to isolate a color.
I can see how I might be able to utilize the getInverseThreshold() function but my testing has had little success. This is compounded by the fact that I don't understand the threshold combination command seen below. Code:
WPIBinaryImage threshold = red.getAnd(green).getAnd(blue); I don't fully understand how the implementation of these works. on a side note where can I find the actual code for all these functions. If i had that it might be unnecessary for me to pose these questions. |
All the functions you're asking about are in the WPIJavaCV project, which should be in the SmartDashboard repository (I see you found it in another thread). getAnd() applies a logical AND to each pixel in 2 binary images:
on AND on = on on AND off = off off AND on = off off AND off = off Code:
on OR on = on on OR off = on off OR on = on off OR off = off Code:
WPIBinaryImage red = image.getRedChannel(),
green = image.getGreenChannel();
WPIBinaryImage redThresh = red.getThreshold(100).getAnd(red.getThresholdInverted(150)),
greenThres = green.getThresholdInverted(75).getOr(green.getThreshold(100));
WPIBinaryImage threshold = red.getAnd(green);
Thanks for the info. Once I knew that getAnd and getOr worked just like the basic programming commands it all fell into place.
