Back shaft on RS-770/775 or RS-550
Hi,
We are looking for 770/775 or 550/540 motors (anything compatible with the PG planetary gearboxes from AndyMark) that have a back shaft (for encoder installation). All we found is a 540 at BaneBots (here). Any pointers would be appreciated. Thanks! |
Re: Back shaft on RS-770/775 or RS-550
FRC use.
Most encoders are not going to be able to handle 15,000+ rpm. This is the US Digital one that I've heard most people use and even the ball bearing version cannot handle anything above 15,000 RPM, which is less than the free speed of the banebots 775s/550s motors. I would recommend that you put the encoder on the final output shaft because it is easiest for the programming team.
We use custom discs that handle these RPMs (and more:-) fine. We need it on the back end due to other design considerations and accuracy.
#7
Don't know - hence the question :-)
#8
Hopefully now that the intent of your question has been clarified you may get some answers from persons who have some insight into the interpretation of R48-I in your situation.
#9
As Michael said, I'd suggest sticking to putting encoders on the output shaft of whatever gearbox you're hooking this puppy up to.
Tolerable RPM, and there's lots of easy ways to hook up an encoder to these gearboxes (generally). |
#10
#12
If anything you want to locate the encoder at the worst possible point for accuracy. Any slop, backlash, etc is all downstream of your encoder and cannot be measured.
#13
This is why I am prodding the OP to provide more detail about what he is trying to accomplish. |
