Go to Post .. just don't try to sell/trade your freshmen or something silly like that. :) - Brandon Martus [more]
Unread 02-12-2012, 23:15
Visualizing 330's software development
I recently ran across gource, which shows the development of a project over time by looking at the commits in a version control system. I pointed it at our CVS server, and this is what it spit out: http://www.youtube.com/watch?v=ct1tIoLJPjs
I thought it was interesting that the programming activity hit the high point around week 6, and stayed strong all the way to the championship.
Unread 03-12-2012, 13:56
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Visualizing 330's software development
Very cool. Are the dots meant to represent files? What causes some of them to branch off?
All opinions are my own.
Unread 03-12-2012, 14:09
Each dot is a file, and each branch is a sub-directory.
Unread 03-12-2012, 15:31
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Seeing that you use LabVIEW, how do you handle merging VI's?
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 03-12-2012, 16:46
We typically tried to avoid merging. We tried to work on different parts of the code, so that people wouldn't have to merge. There were times where someone delayed implementing a change until someone else had finished with that VI. When we failed to communicate and ended up needing to merge, we used the LabVIEW merge tool, which most of the time worked fine.
One thing we noticed is there are times when there were unexplained changes (someone didn't explicitly change a VI, but it changed anyway). We were able to minimize these by turning on the separate compiled code from VIs. We also made each global variable its own VI, because we found that changing anything in the global variable VI made LabVIEW recompile every VI that uses that global variable VI).
Unread 03-12-2012, 21:48
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
I think the more teams that see this the more teams will make better use of version control .
In all seriousness, wow, I'm jealous I'm going to use this for the team and personal projects .
Unread 13-10-2013, 21:15
I ran the gource visualization again for our code this past year. http://www.youtube.com/watch?v=OBuoa5eqmbM
Unread 13-10-2013, 23:47
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
If that was our screen, it would have been completely black until the day of our first regional. Our code just didn't work (for reasons unknown) when we switched cRIOs (from practice to comp bot) plus we (stupidly) forgot joysticks and had to buy new ones (different). Our lead programmer was up all night Thursday and we played the 1st match Fri without a hitch
Unread 14-10-2013, 09:52
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
This is very cool! I think it gives a very good representation of what actually takes place over a season.
I wonder if teams could use this as a visualization on mapping out what has been done in code and what needs to be done next.
I really like this. Thanks!
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 22-01-2014, 22:56
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
I just compiled and ran this on our repos for the last two years, that was absolutely amazing!
Thank you for sharing this great find!
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
