Submitting Animation
I put the animation together in WMV, how do I get that into an ISO?
Re: Submitting Animation
[They want an encoded video DVD, and not simply the WMV file dropped into an ISO] Last edited by dcarr : 06-12-2012 at 23:06. |
If you guys need help, feel free to drop by CHS sometime! Good luck
So I should just put it onto a DVD? I thought I was supposed to submit online... So confused!
Instead of burning to a physical DVD, you're "burning" to an ISO disc image, then uploading that through STIMS.
So, how would I do that? Just click Burn DVD? and then go through that?
#7
[A round-about way of doing this would be to burn a standard DVD and then use ImgBurn to create an ISO from that, but you should be able to do it in one step. Last edited by dcarr : 07-12-2012 at 01:33. |
#8
What version? I didn't think Windows Movie maker had DVD authoring functionality.
#10
It can publish DVD's, I think the 2003 version is better actually. I think I'm using newest though.
#11
Just to clarify, an ISO image is just exactly the same as what is burned to a DVD but saved on your hard disk as a file. You have to create it like that, you can't just copy the data off of the DVD. Most programs that can burn a DVD can also make an ISO file.
#13
![]() We use Encore (linked project from Premiere) which allows straight-to-ISO. |
#14
Using Encore as well. It seems they wanted specifically a Region 1, so make sure you select that in the build options in encore. Boy, what a pain to find a program with that option (No way were missing out on a region code error)
#15
Just got word from our moderator and when they went to upload it gave them the option to use a .avi file instead of an iso.
Well, I guess I wont get that hour of my life back... |
