Go to Post I think another really awsome thing about FIRST can be summed up by what Dan, the Wildstang operator, said when they won nats: "I built that!" I mean, the feeling of satisfaction you get knowing that something you created can perform such unbelievable tasks is amazing. - Jupee [more]
Unread 05-01-2013, 06:16
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Post RobotBuilder Relative Path patch
I've been playing with RobotBuilder, and it's an awesome tool, but there's one big problem I have: its export functions work only on absolute paths. This isn't a problem if you only have one person working on a project on one computer, but if you're working with multiple people across multiple computers (sometimes with different OSs), like in FRC, this becomes problematic really quickly. So I wrote a fix myself.
The functionality is pretty simple: it doesn't add a relative path option to the directory selection dialogs, but if you edit the .yml file to use a relative path, it will work (relative to the .yml's directory).
To use this, first checkout the RobotBuilder project, then use the "svn patch" command (svn 1.7 required) on *nix. I'm not sure how exactly you'd do it on Windows, but this StackOverflow question might help. Otherwise, you can do it by hand: the lines starting with --- and +++ indicate the file the changes apply to, the lines starting with @@ indicate the lines affected, the lines with nothing in front are context, the lines starting with - are deleted, and the lines starting with + are added.
I also sent this to the developers, so it might end up being incorporated into the official project, but if not, I figure you guys might want to use it
I code stuff.
