Can we THROW through the feeder slot?
One of the first questions I had when i saw the video. Anyone that's thrown a frisbee down against the ground knows how it bounces back up and goes a lot farther. The feeder slots in the video looked about 45 degrees down (though admittedly I havent seen the blueprints yet).
Did anyone else think about this? Happen to see a rule about it that I missed? If it's not prohibited this would be a great strategy to feed them to your robot across the field |
Re: Can we THROW through the feeder slot?
I don't see anything against it in the Manual, so I would say yes that's perfectly legal. because you are putting the Game piece through it's intended slot.
Section 2.2.7
I imagine that it would be hard to throw a frisbee through an eight inch long slot. Anybody tried yet? |
Can we make a device to throw it accurately through the slot or is that not allowed?
I don't think that would be allowed.
I don't see the eight inches being the problem, I see the incline being the problem. If you actually want to throw the disc through the slot, you're going to be aiming straight down, and drawing it out makes me wonder whether a bounce shot through that slot is even possible. Last edited by slijin : 06-01-2013 at 12:09. |
#7
Looking at the videos and pictures of the feeder station, it's definitely going to be a tight fit if you plan on throwing them.
- Sunny G. |
#8
We were at the kickoff with the real field and there is going to be no way to throw through the feeder slots. You might be able to push really hard and have it go a little further, but there won't be enough momentum to bounce and go further. The slot is really just big enough for the disks, to the point that several people got them stuck in there a bit when trying to push them through.
#9
I'm not undstandimg how the slots are 8 inches long. Aren't the frisbees 10.625 inches wide in diameter?
#10
As Trent said, the slots themselves are 12" wide and 3" tall. The 8 inches refers to the length, or depth, of the tube that it has to pass through as it goes into the field. Last edited by slijin : 06-01-2013 at 12:48. |
#12
Ah, thank you for the clarification.
#13
The incline is 8 inches and it is open on the ends. The slot itself is wider and taller than the Frisbees (12x3)
