off CRIO on robot Vision processing and ports
So if I use a odroid-u to do vision processing on the robot it should not matter what port I am using. I am routing on the robot. Is this correct?
Re: off CRIO on robot Vision processing and ports
See <R58>
R58 Ethernet-connected COTS devices or custom circuits may connect to any remaining Ethernet port but must not transmit or receive UDP packets using ports 1100-1200 with the exception of ports 1130 and 1140. Thanks. |
