Go to Post Most of us are pretty friendly. - StephLee [more]
Unread 07-01-2013, 16:06
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
2013 Kitbot Problems
We are trying to put together the 2013 kitbot drivetrain based on the instructions provided by FIRST. It appears that the spacers for the wheels are too small. Did we make a mistake or did FIRST send the wrong size spacers?
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 07-01-2013, 16:46
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: 2013 Kitbot Problems
I put it together yesterday. Andy mark has vid's available. That would probably be helpfull.
Good luck.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 07-01-2013, 22:16
Erik Huang's Avatar
Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
Good luck.
296 put together the wide version of the kitbot (although we did modify it quite a lot). If you're doing the wide build, then you have to cut two of the brass spacers included (check the video/manual for the actual dimensions, but I think it was something like 1.62").
Another thing: There is a discrepancy in the assembly steps.
On the video, the short belt goes on the pulley with spacers on either side.
In the assembly guide in the KoP, they tell you to put the long belt on the puller with spacers on either side (basically the spacers on the front and rear are mixed up).
We found it easier to go with what they tell you to do in the assembly video. The belt is still a little tricky to get on, you have to kind of wiggle it and aim in at a downward angle. Either way, good luck!
Here ye, here ye! Here cometh the robot!
Unread 09-01-2013, 08:36
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Is it the long or wide base configuration?
Unread 09-01-2013, 11:55
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We had the same problem... be sure that you put the bearings in the belt pulleys and not in the wheels themselves. The bearings need to mount on the outermost part for this drive system. Sometimes it is in a wheel, sometimes it is in the belt drive pulley.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 09-01-2013, 12:01
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Harsh,
I was looking at it yesterday with Daniel. The first thing that needs to be done is swap the outer frame rail around on one side. It has the center drop hole on top, not the bottom.
Next, FOLLOW THE DIRECTIONS!!
We should be having one of the experienced students working with the newer students. (This is where I need a "Facepalm" emoticon.)
