Shared Testing Pyramid Locator - Post here if you are willing to share your pyramid
Along with the threads on pyramids and game fields being shared, I figured we could post a thread to capture all teams that have elements that are willing to share.
Team Number Team Name Location (City, State) Primary Contact Email (if applicable) Primary Contact Phone (if applicable) Field Element (High, Mid, Low, Full driver station wall, Pyramid ("Real" or "Team Drawings"), Feeder Station, Low Goal, Entire Field) Please fill out your information in this Google Docs Form. If you are unable, post to this thread and I will add to the list. The compiled results are in this Spreadsheet. I'm not sure how long I will be able to edit this post, so I'll do my best to capture the information on Google Docs. Last edited by protoserge : 08-01-2013 at 10:50. |
Re: Shared Testing Pyramid Locator - Post here if you are willing to share your pyram
Contact: ezygmont@team708.org Element: Pyramid (Team Drawings), Feeder Station Last edited by ezygmont708 : 08-01-2013 at 13:44. |
Location: Manassas VA (Roughly 30 miles south and west of Washington DC)
Contact: OPHSrobotics@gmail.com Elements: Team Feeder station (Done) Team Low Goal (Done) Team Middle and High Goal (In progress) "Almost competition" pyramid (should be done in about a week) |
*Hybrid Team/Actual pyramid means that our team will be following the Actual pyramid specs for the most part, though we will not be wielding if we can avoid it, as well as possibly adding some gussets on the inside of the corners, depending on how stable it turns out. |
Team drawings, my apologies... is sturdy, will be sturdier with the goal on top
#7
...was hoping more people would have posted here. I'm guess most teams don't have space to store a steel pyramid.
#8
We are finishing the pyramid today, but:
Team Number: 1676 Team Name: The Pascack Pi-oneers Location (City, State): Montvale, New Jersey Primary Contact Email (if applicable): hallry@pascack.k12.nj.us Primary Contact Phone (if applicable): Email is the best way to contact Field Element: Carpet, High Goal, Mid Goal, Low Goal and Feeder Station (with slots), Driver Station table, "Real" (Steel EMT, wielded) Pyramid with Pyramid Goal Note: Our Pyramid is designed to be able to be disassemble-able, since we have to set-up and then store our field elements each day if we want to use them, either outside, in our normal ceiling autoshop or cafeteria, or in our high ceiling gym. |
#9
Team Number: 2851
Team Name: Crevolution Location (City, State): Sterling Hgts, Michigan Primary Contact Email (if applicable): crevo.robotics@gmail.com, bryan.battaglia@uticak12.org, ryan.caldwell@baesystems.com Primary Contact Phone (if applicable): Email is the best way to contact Field Element: Full field (only when dedicated to scrimmage) minus one pyramid. (The pyramid we have is based on the Team drawings) Half field will be open to testing all the time. (our setup this year is due to the velocity of game pieces "safety first" we'd have to close our fab area to safely play at both ends of the field) crevolutionrobotics.org there is a map to our build site in the contact link. Build site hours are 4-8 Mon-Fri 10-6 Sat, we're looking forward to seeing other teams towards the end of the build season to run some scrimmage matches etc... |
#10
Team Number: 2791
Team Name: Shaker Robotics Location: Latham, NY Primary Contact Email: info (at) team2791 (dot) org or PM me Primary Contact Phone: N/A Field Element: We will have 1/4 of a field spec pyramid by end of week 4. (i.e. one corner.) Teams in Upstate NY, Western MA, and VT should note that Team 20 has a full practice field with field elements based on team drawings at RPI's Tech Park in Troy, NY. Contact them for more details. We are a 7 min drive from this facility and we can arrange to meet you there for practice with our 1/4 pyramid after week 4. |
#11
I've updated the master spreadsheet with all the non-submitted posts so far.
Thanks for the responses so far ![]() I haven't had time to make the mapping tab show the team details per the location yet. I have to do a bit more reading to make that work. |
#12
Team Number: 126
Team Name:Gael Force Location: Clinton, MA Primary Contact Email: GaelForce126@gmail.com Field Element: Full playing field, pyramids are welded. Only element currently not finished is pyramid goals. We have a full field, with alliance walls and drivers stations areas, in the Central Mass area. Please contact our team email, or me personally (aj.dd549@gmail.com) if interested. Steel toe shoes and safety glasses are required for everyone in our warehouse. We can assist with anyone that may not have shoes. |
#13
Team Number: 45
Team Name:Technokats Location: Kokomo, IN Primary Contact Email: leadership@technokats.org Field Element: one 3 pt goal, one 2 pt goal, one 1 pt goal, 1 pyramid (team version), one pyramid goal, and one feeder station. We have a full sized field and a red and blue set of driver stations. Just shoot us an email and we'll see that you can stop by. |
#14
Thanks. Updated!
#15
Team Number: 1640
Team Name: Sab-BOT-age Location: Exton, PA Contact: Siri Maley, skm5107 at psu dot edu, 484-883-7596. Please call ahead so we can clear the date appropriately. Field Elements: 1 of each goal (team drawings), 1 pyramid (almost-real*), 1+ feeder station (team drawing with slides). Half or full court carpet, potentially boxed in ("walls"). *Welded steel conduit; correct OD, rung heights and angles; but undersized horizontally by 4" |
