Go to Post FIRST is a learning, growing and inspiring organization. We can never dictate pretty. We can however encourage and teach quality. - Steve W [more]
Unread 08-01-2013, 15:13
Cody Burd's Avatar
Cody Burd Cody Burd is offline
FRC #3607 (Technologic)
Cody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to allCody Burd is a name known to all
Goal to Pyramid
Hi i cant find this anywhere in the rules i want to know how far away from the front of the pyrimid is to the goals
Unread 08-01-2013, 15:35
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Goal to Pyramid
The field is 54' across (section 2.2.1).
The pyramid starts 108" away from mid-field (drawing, link below which is referenced in 2.2.1)
The pyramid base is 94" across (section 2.2.5).
Use some math for the exact answer, and tbh you should verify that these #'s are correct too. You have to derive this information from what you're given. I can't tell if the GDC intentionally forces teams to do this (since it's what happens in the real world) or if they don't want to have trouble maintaining dimensions in many different spots as the rules reference drawings.
Drawings, FE-00036 page 5
GitHub
Unread 08-01-2013, 16:04
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: Goal to Pyramid
I think part of why FIRST does not explicitly specify all dimensions, such as the distance from the pyramid to the end of the field is to minimize the critical dimensions that teams may hold them accountable for. Repeated setup and teardown of such a large assembly of parts such as the FIRST field cannot guarantee an exact dimensional consistency throughout dozens of events.
They even clearly state in the 4th paragraph of the Arena section that they will try and make the field configuration as consistent as possible from one event to the next, but guarantee no better than 1/4" tolerance on large field assemblies, and 4" tolerance on gross field dimensions.
So you can calculate and work off of the nominal dimensions, but it would be smart to make sure that your design can tolerate some variability.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
