Go to Post We are not here to build robots, or to win a contest, or to travel to cool places or to bring home trophies. we are here to see what a career in engineering and science is like; anything else that happens along the way is frosting on the cake - KenWittlief [more]
Unread 08-01-2013, 22:42
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
clandry94 is an unknown quantity at this point
Software control or gearing
My team is going to be using a linear shooter with two wheels and is still deciding on whether we want to run the front wheel faster than the back wheel. Anyway, if we want to run one slower is it possible to put a limit on a Victor motor controller to have a max amount of output as to make the rear wheel run slower than the front instead of running max power, but having the rear wheel geared down. Are there any pros or cons to this?
Unread 08-01-2013, 22:54
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: Software control or gearing
Yes, you can cause the rear wheel to run slower if it is driven off of a second Victor. You don't necessarily have to put a limit on it, but you could have it scale. (I.e. if you run the front wheel at speed X, you can run the rear wheel at speed 0.80*X)
Anyways, I don't see anything wrong with doing either, but that's just on the software side.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 08-01-2013, 23:46
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
If both wheels have the same gearing, making one slower in software will have no benefit.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 08-01-2013, 23:55
Why not ?
Unread 10-01-2013, 00:09
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Why not ?
^This. Software control should be used anyways along with some feedback mechanism for determining RPM, as invariably the power level required to get a wheel to spin at a certain speed will change over time due to various factors.
Attending: MN Duluth Regional
Unread 10-01-2013, 00:18
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Which option would be better for your team?
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 11-01-2013, 22:50
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
Has there been a tested advantage to having a wheel move slower than the other? Our team will start our shooter prototype on Monday (Bit of an ordering delay for needed parts) and I am curious about this now...
Unread 11-01-2013, 23:38
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
I believe RobotIn3Days did something like that, but basically what the issue was that without a controller, the first wheel slowed down quite a bit first, so a second wheel was used to boost the muzzle velocity. Having the first wheel move slower would theoretically allow more overhead for a controller to work to improve the performance, but then again using the proper controller for a shooter wheel would improve the performance without the need for a second wheel.
Alternatively, without a controller, you could simply use the slower wheel to gradually speed up the wheel, so you might be able to shove more shots through.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 12-01-2013, 00:07
Originally Posted by nathan_hui View Post
using the proper controller for a [linear] shooter wheel would improve the performance without the need for a second wheel
I haven't seen any videos of a successful linear shooter with only one wheel.
With a linear shooter, the frisbee has only a fraction of the contact time that a curved one does. Because of this, the acceleration in the linear shooter must be much greater to achieve the same exit velocity.
Beyond a certain acceleration, excessive slippage will occur, resulting in poor performance.
Adding a second wheel increases the contact time, reducing the required acceleration, and reducing the slippage.
Unread 12-01-2013, 01:08
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Any thoughts on the viability of a hybrid shooter? IE, one that starts out with a small curve (say a 45 degree arc) and then straightens out and gets boosted by a second CIM?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 12-01-2013, 01:32
AKA: Conor
We considered that, but couldn't determine a design that would fit within our robot perimeter unfortunately.
Unread 20-01-2013, 02:44
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
I haven't seen any such videos either, but I also haven't seen any one wheel axis, linear shooters where the pinch edge opposing the one wheel is capable of dynamically flexing and pivoting enough, as the disk passes through, to significantly expand length of the arc segment of contact with the single wheel.
I also haven't seen much reporting on the seriously wide variations of wheel-to-disk friction grip that different formula urethane wheel materials can produce.
We have already found that premium skate wheels at durometer a measured firmness of 75A have dramatically better grip than other wheels only slightly firmer, and with a seemingly less "grippy" urethane formula.
In the wold of skate wheels (boards, inlines, and quads) the range or tweaking of urethane formulas to achieve grip, roll and rebound performance benefits is quite incredible. I highly advise all teams who are doing small wheel (one or two) shooters consider evaluating their options in the skate wheel category. Lots of size selections also available.
These efforts could prove to be as valuable as RPM tweaking, or at least supplement them.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 12-01-2013, 02:15
Mr V's Avatar
Mr V Mr V is online now
FRC #5588 (Reign)
The system can not respond fast enough for a "proper controller" to maintain its speed when accelerating the disc. By the time the control system can sense that it needs to add more power the contact event is most of the way over, at least on a linear shooter particularly if you are using a PID loop.
Unread 12-01-2013, 02:12
Mr V's Avatar
FRC #5588 (Reign)
Yes it will, the slower wheel can accelerate the disc a certain amount w/o slippage pass it on to the second wheel which can accelerate in more w/o slippage.
