Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Unread 09-01-2013, 19:26
eklaw eklaw is offline
eklaw is an unknown quantity at this point
Direct drive with CIM?
Our team wants to be able to direct drive a wheel hub with a CIM with 1:1 reduction. The issue is that we dont currently have the adapter necessary to go from the CIM shaft to adapt to our 1/2" shafts and hubs. Can anybody point me to a place to buy such a coupler? Thanks!
Unread 09-01-2013, 19:32
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Direct drive with CIM?
Take a look at McMaster and Ruland
www.mcmaster.com
www.ruland.com
If you've got a lathe and you have a full set of drill bits (letter, number, and fractional), consider making your own. A #21 drill bit should be a good fit for a 4mm shaft (4mm is .15748, #21 is .159)
You may have to settle for some misalignment in the shafts, since you may have to approximate one dimension or the other. If so, take a look at Ruland's couplings that allow shaft misalignment (last three on the front page)
EDIT: 8mm? use a O drill bit (.316). 8mm is .314961
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 22:05
DonRotolo's Avatar
Back to humble
FRC #0832
or you can buy an 8 mm drill bit.
Seriously, unless you understand and can implement the concept of precise concentric boring (e.g. on a lathe) buy a coupler at the correct size.
Unread 09-01-2013, 22:24
As a caveat, the CIM is a great motor but...
It only has sleeve bearings around the output shaft. If you are planning to implement a design that has significant side loading, be prepared for bearing failure. The motor shaft needs some additional support when used in this fashion.
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
AndyMark has a hub that will attach directly to a CIM motor.
http://www.andymark.com/product-p/am-0320.htm
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 09-01-2013, 20:07
gibbta gibbta is offline
FRC #2417
gibbta is an unknown quantity at this point
I would not recommend doing this last year we had direct drive for are shooter and when we turned it on all the control lites on the robot would fade out and c-rio would turn off. Testing it off of a test board and a real board are very diffident things. But outer then that warning we made are a custom cim to wheel hub.
Unread 09-01-2013, 20:09
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Huh?
I'm about 100% positive you can direct drive a CIM on a competition robot. Your issue is something else sir.
-RC
R.C.
MadTown Robotics Team 1323
Unread 09-01-2013, 21:59
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
I'd recommend against going straight to 100%, as this would essentially cause a full short through the motor while it spins up and thus cause a huge voltage drop on the robot. A gradual ramp up in duty cycle would be better to spin up the CIM, although it would take longer than full duty cycle.
Attending: MN Duluth Regional
Unread 09-01-2013, 21:36
O-H
FRC #0048 (Delphi E.L.I.T.E.)
They also offer these products:
http://www.andymark.com/product-p/am-0472.htm
http://www.andymark.com/product-p/am-0588.htm
