Go to Post By affiliating yourself with a team, you are representing them at all times, as you are a member and part of that team. - Chris is me [more]
Unread 10-01-2013, 15:06
Warhawks Warhawks is offline
FRC #2554
Warhawks is an unknown quantity at this point
Accessing camera output
We want to access the camera output in order to draw lines on the video.
Is there any way to do this so that the drawings appear on the driver station as the video is shown in realtime?
Notes:
-Using Java.
-The shapes do not cover the whole picture, only a small portion. The rest of the video should still be playing in realtime.
Unread 11-01-2013, 20:36
FRC #2554
Re: Accessing camera output
Any ideas?
Unread 11-01-2013, 21:19
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Your best bet is to just edit your dashboard and just add a line to the display. Are you using the Smart Dashboard (gray in color) or the Labview Dashboard (Blackish in color)?
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 12-01-2013, 04:13
sretter's Avatar
sretter sretter is offline
AKA: Shaked
FRC #2231 (OnyxTronix)
sretter is on a distinguished road
If you are using Java I'll assume you are suing the SmartDashboard, then you can make a extension which extends the WPICameraExtension, and then you can overide the process image method- using rawImage.drawPolygon(I think there a more methods you can use tlike drawLine or drawRectangle) and then return the new rawImage.
This way you will have whatever shape you pick on the camera Image and the video running behind it
Unread 12-01-2013, 20:10
FRC #2554
I am new programmer for the team, I can't find "WPICameraExtension", and please provide more details. Thanx.
Unread 13-01-2013, 00:26
Johnbot's Avatar
Es Brokein!
AKA: John Westhoff
You need to install http://firstforge.wpi.edu/sf/frs/do/.../frs.installer
And then import everything under
C:\Program Files\SmartDashboard
and
C:\Program Files\SmartDashboard\extensions
and
C:\Program Files\SmartDashboard\extensions\lib
into your Java Class Library (a type of project you can start in Netbeans)
You will want to have your extension class extend WPICameraExtension.
You will also want to override the method processImage, as sretter has said.
Unread 13-01-2013, 20:02
FRC #2554
and
and
You will want to have your extension class extend WPILaptopCameraExtension.
Thank you for clearing things up, I have imported the .jar files in these folders but when I try to use the classes in these files I get compile time errors such as: "cannot find symbol symbol: class WPILaptopCameraExtension", although when editing the class the IDE (NetBeans 7.2) doesn't give these errors. I have checked "java sources classpath" multiple times but still the same.
Unread 13-01-2013, 20:50
Johnbot's Avatar
Es Brokein!
AKA: John Westhoff
Did you tell NetBeans to include the SmartDashboard jars as libraries?
Right-click your project, click Properties, click Libraries, and hit "Add JAR/Folder" and the choose SmartDashboard.jar, and then repeat for WPICameraExtension.jar, WPIJavaCV.jar, javacpp.jar, javac-windows-x(VERSION).jar, and javac.jar.
Unread 13-01-2013, 22:33
FRC #2554
yes i did, still the same error(s)
Unread 13-01-2013, 22:57
Johnbot's Avatar
Es Brokein!
AKA: John Westhoff
Oops, the mistake is on my part. I told you to extend the widget for accessing the computer's camera instead of the Axis Camera.
You should be extending WPICameraExtension, not WPILaptopCameraExtension, my apologies.
Unread 13-01-2013, 23:30
FRC #2554
Oops, the mistake is on my part. I told you to extend the name of the jar containing the default camera widget.
that is not the actual problem here, the compiler somehow cannot read the libraries that I imported, for example after I changed it to "WPICameraExtenion", I still get the same error: package edu.wpi.first.smartdashboard.camera does not exist
import edu.wpi.first.smartdashboard.camera.*;
this error occurs only during compile time, mean while, when I am editing the code, I don't get the this error. God, I have been spoiled with Visual Studio and C#.
Unread 12-01-2013, 20:08
FRC #2554
I am using the SmartDashboard.
Unread 14-01-2013, 22:34
FRC #2554
Solved the problem, thanks to everyone who corresponded
Unread 15-01-2013, 10:45
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What was the solution to the problem?
