Go to Post The evil Chief Delphi machine will begin to consume you and your non-robotics life thread by thread. First hand experience :D. - frcguy [more]
Unread 12-01-2013, 12:09
TRIBE TRIBE is offline
FRC #3651
TRIBE is an unknown quantity at this point
How to create a direct drive for an AndyMark 0915 Motor (am-0912).
We want to connect directly an AndyMark 9015 Motor (am-0912) and a standard 8 inch wheel in order to achieve the rpm we desire (somewhere around 8,000). How would we do this?
Unread 12-01-2013, 12:25
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: How to create a direct drive for an AndyMark 0915 Motor (am-0912).
We're using these.
Hi!
Unread 12-01-2013, 17:20
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Why do you need 8k RPM? What kind of torque do you need from the motor? Directly driving the wheel may not be a good idea, make sure that the numbers say that this is the best solution
The output shaft on the AndyMark 9015 motor (am-0912) is 0.125 diameter. A "standard" 8 inch wheel has a 1.875 bolt circle (#10 bolts). The problem is, no one (that I know of) makes a hub that goes on a .125 shaft.
One possibility is to manufacture a bushing with a 0.125 (undersized if possible by 0.001) ID and a .500 OD. If you key the bushing on the outside with an ANSI keyway (1/8 for 0.500 OD), you could press the bushing onto the motor output shaft and fit a 500 Key Hub (am-0077) onto the bushing to mate with the wheel. One thing is that this bushing must be made perfectly, or the wheel will destroy the shaft.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 12-01-2013, 20:08
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
You can use a versaplanetary 10:1 gearbox to make a 1:1 adapter. Just pull the whole ring gear, planets, sun and the middle housing section. The output shaft mounts right to where the sun was and you just screw it back together. We had a wheel spinning at 19,000RPM off a BB550 motor for one of our prototypes. We're using very small wheels.
The versaplanetaries come with a 1/2" hex shaft but you can modify it to a 1/2" shaft with key way.
