Go to Post Adding more weight doesn't make the challenge any easier, it just makes the robots heavier. - Sean Schuff [more]
Unread 12-01-2013, 19:44
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
pic: WCD: 1515's Tentative 2013 Drivetrain
Unread 12-01-2013, 19:46
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
Re: pic: WCD: 1515's Tentative 2013 Drivetrain
are the gearbox's is in that middle
Unread 12-01-2013, 19:47
in the middle***
Unread 12-01-2013, 20:17
FRC #1836 (MilkenKnights)
Yes. This is a relatively typical WCD using the WCP gearboxes.
Unread 12-01-2013, 22:59
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Well, now you've gone and made me download Inventor again.
Looks good, though I'm curious, do you have a massive connector for the electronics board, or do you have to remove all connections to the robot separately to be able to completely remove it from the bot?
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 12-01-2013, 23:10
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
My team was thinking about using the WCProducts gearbox too, however it says out of stock. Have you been able to contact RC about if they are actually out of stock or if the website just isn't updated?
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
