Go to Post And whether or not we are awarded in the course of the season, at its end our team will look back, and we’ll look at one another, and we will wonder how we were able to accomplish what we did. - John Wanninger [more]
Unread 14-01-2013, 15:20
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Using an Non First Microcontroller with Victor 884 Motor Controller
Hi I am trying to use a Victor 884 motor controller with a non first micro controller. I dont want to use a PWM driver.
Does anyone know any information about the PWM signal used to control the Victors?
Period, Voltage, Current ect...
Thanks
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 14-01-2013, 15:47
miker4004 miker4004 is offline
FRC #4004
miker4004 is an unknown quantity at this point
Re: Using an Non First Microcontroller with Victor 884 Motor Controller
My understanding is this:
1ms - 2ms pulse width with 1.5ms being center(off) , the 1ms full rev and 2ms being full fwd.
refresh rate or period is 50hz. signal level is a ?. It seem that 5volts was the output but I know that we had issues with some RC type outputs being to weak to drive one.
Unread 14-01-2013, 16:04
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
There shouldn't be a problem using "something else" to control your motor controllers for testing or non-competition uses. But please check the rules if you're thinking of sticking it on the robot this year!
2016: Lake Superior WFFA
Unread 14-01-2013, 17:10
this from apalrd:
Originally Posted by apalrd View Post
The current PWM setup in WPIlib (at least in LabVIEW) is a PWM output with a 5s period and a 'period multiplier' of 1,2 or 4. It's enumerated, so 1x, 2x, and 4x correspond to 0,1,2 respectively (I don't think you can add more multipliers if you want).
The Jaguars use a period multiplier of 1, for a 5ms period. The Victors use 2, for a 10ms period. Servos use 4, for a 20ms period, and raw PWM channels can use whatever they want (of the three choices)
Unread 14-01-2013, 19:13
jamie_1930's Avatar
Team Role: Student
I'm using them for the 2013 Robomagellan Competition in San Mateo, CA not a FIRST event so FRC rules don't matter. Thanks for the help, but does anyone know what the minimum and maximum current is for the motor controller?
2009
2008
Unread 14-01-2013, 19:21
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Maximum: 40 Amps Continuous, No minimum current.
More information can be found here (which to my understanding is the only place 884's are being sold!): http://www.robotmarketplace.com/products/IFI-V884.html
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 14-01-2013, 19:49
Originally Posted by McGurky View Post
No minimum current.
Where did you get that info from ?
Unread 14-01-2013, 19:57
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Since you can turn them on and run them with no load, this implies no minimum current. Keep input voltage around 12. The pwm signal should be pretty low current. Any standard microcontroller output should provide enough.
Thanks for the 5 and 10ms info. I find that quite helpful.
Unread 14-01-2013, 20:02
Ever look at a graph of output current vs input command for an 884 ?
Unread 14-01-2013, 20:00
jamie_1930's Avatar
Team Role: Student
When I say max and minimum current I mean for the controlling signal going in to the Victor (the pwm).
2009
2008
Unread 14-01-2013, 20:04
Yes, there is a minimum current required to operate the opto-isolator in the Vic's input. Don't know off-hand what it is.
There's also a max current above which the opto-isolator can be damaged.
Unread 15-01-2013, 14:52
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Our test box is using a Microchip PIC12F675 to generate a PWM signal for the motor controller. The box drives Victor 883s, Victor 884s, and Talons well. Our black Jaguars pretend it doesn't exist. The timing we use is 1mS on equals full reverse, 1.5mS on equals neutral, 2mS on equals full forward, with a rep rate of 244 Hz. We have a 270 ohm resistor in series with the PIC output pin to allow it to survive inadvertent shorts to ground.
The Talon manual states an input frequency of 333 Hz, but it seems quite satisfied with 244 Hz, and allowed me to be lazy with the code in the PIC.
Unread 15-01-2013, 15:11
The Jaguars use a slightly different PWM scheme than the standard hobby servo. You have to modify the PWM for the Jaguars to react.
Unread 15-01-2013, 15:12
Our black Jaguars pretend it doesn't exist. ... We have a 270 ohm resistor in series with the PIC output pin to allow it to survive inadvertent shorts to ground.
How much current can that PIC source thru that 270 ohm resistor?
There's a minimum threshold current required to trip the detection circuitry in the motor controller.
I believe all three motor controllers will accept periods from 5 ms up to 20 ms. Some will accept periods outside that range. The period does not affect the motor controller's interpretation of the input PWM signal. It is reading the pulse width, not the duty cycle.
Your period of 4 ms (244Hz) is overkill. The fastest period used in the WPILib drivers is 5 ms.
Unread 15-01-2013, 15:21
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
The PIC output is sourcing 10mA to the one Victor 883 I measured. That's a reasonable input current for the optoisolators I'm used to. I'm pretty sure (but not certain) that the 883, 884, and Talon have optoisolators at the PWM input.
