Go to Post we've got three years to perfect it. And then... who knows? - Amanda Morrison [more]
Unread 14-01-2013, 17:16
Priyesh69 Priyesh69 is offline
FRC #3988
Priyesh69 is an unknown quantity at this point
Imaging tool error
Hi we are trying to update our crio. We are getting this message error on the screenshot. Here some information for what we are using.
Yellow crossover cable
local wireless connection ip:10.39.88.6 sub:255.255.255.0
router ip 10.39.88.6
crio ip: 10.39.88.2
Name:	Sans titre.jpg
Unread 14-01-2013, 17:50
Re: Imaging tool error
crio ip: 10.39.88.2
The router IP is probably 10.39.88.1, because having the same IP as your laptop will prevent them from communicating.
You should check on that.
P.S.
You should click the box that says "Always run deployed code at startup"
Unread 14-01-2013, 19:20
FRC #3988
Ok we will try that and for the startup since we will be running lots of defferent programmes and changing them we will turn the startup on during competitions
Unread 14-01-2013, 20:27
...for the startup since we will be running lots of defferent programmes and changing them we will turn the startup on during competitions
Then don't expect them to run if you don't start them.
Unread 14-01-2013, 21:25
FRC #3988
i didnt quite get the 10.39.88.1 where do i entre this ip
Unread 14-01-2013, 21:54
The router is assigned an IP address of 10.te.am.1, so in your case it's 10.39.88.1
It is set for you by the FRC Bridge Config Utility, although it can be set by hand too.
The convention for the IP addresses we use are:
  • 10.te.am.1 - router
  • 10.te.am.2 - cRIO
  • 10.te.am.4 - (used if an additional router is desired)
  • 10.te.am.5 - Driver Station Ethernet
  • 10.te.am.6 - programming laptop
  • 10.te.am.9 - Driver Station wireless
  • 10.te.am.11 - Axis camera
Unread 15-01-2013, 04:13
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Mark, I was under the impression that the .4 IP is supposed to be the default gateway for everything in the robot network. What do you use as the gateway IP?
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 15-01-2013, 08:02
There is no gateway in the network, so you can leave that blank.
Supplying a fictitious IP address for a device that doesn't exist (e.g., .4) won't harm things, but it also won't matter.
When this FRC control system was first developed for the 2009 season we were issued a router used at the driver station plus a separate robot bridge. That router was assigned the address 10.te.am.4. However, that router wasn't a gateway either.
A gateway typically takes you to a WAN or Internet, not to someplace else on the same LAN.
A gateway is a transition point from one type of network to another.
Since none of our robot network traffic leaves our LAN, a gateway is never used or even looked for. (and by IP convention private IP addresses like 10.xx.yy.zz are not allowed through gateways anyway)
In general, the gateway field is only required when you have a more complex network where network traffic must hop across several different types of networks or get out through an Internet Service Provider.
Unread 15-01-2013, 13:13
FRC #3988
We tried to connect with this ip: 10.39.88.1 and we also tried to connect with the two subnet: 255.255.255.0 and 255.0.0.0, the same error message, as the screenshot show it, appears
Unread 15-01-2013, 13:27
Try Disabling all other network interfaces on your laptop, e.g., wireless.
Leave only the Local Area Connection Enabled.
Use an Ethernet between the laptop and the router and another between the router and the cRIO.
Control Panel->Network and Sharing Center -> Change adaptor settings
right-click on the one's you don't need -> Disable
Start the Driver Station app and see what the ping tests show on the Diagnostics tab.
You should see green lights for Enet Link, Bridge, & Robot
Unread 15-01-2013, 15:29
FRC #3988
All the other network interface are disabled, but we still can`t update the cRIO with the imaging tool
Unread 15-01-2013, 21:08
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
To put it simply our classmate is not available at the moment
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 15-01-2013, 21:13
inkspell4's Avatar
Could it have anything to do with the laptops firewall permission settings?
Unread 17-01-2013, 16:03
FRC #3988
I don't think so because when you run the imaging tool there's a pop-up for the firewall.
Unread 17-01-2013, 21:49
inkspell4's Avatar
Our problem ended up being the firewall
