Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 14-01-2013, 21:17
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
DLink Radio Wont Connect To DS Wirelessly
As the title says the radio will not connect to the DS wirelessly while it will when connected to ethernet.
Here is what we have done:
-Set up the router using the supplied utility
-Imaged The CRIO
-Uploaded Code
Any ideas?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 14-01-2013, 21:43
Re: DLink Radio Wont Connect To DS Wirelessly
If you're using a Classmate, make sure you setup the router for 2.4GHz
Make sure the Classmate wireless is on and the IP is set correctly.
If using a different laptop make sure it supports N and the frequency you chose.
Unread 14-01-2013, 21:44
inkspell4's Avatar
Were not using the classmate and our laptop will connect but the radio is not recognized by the DS
Unread 14-01-2013, 21:49
The Driver Station doesn't have to recognize the router.
It does have a ping for the IP of the router. Is that what you mean is missing?
Unread 14-01-2013, 21:50
inkspell4's Avatar
It does have a ping for the IP of the router. Is that what you mean?
We can use the computer to connect to the router but the DS acts as if there is no connected router.
Unread 14-01-2013, 22:01
You're going to make me keep guessing aren't you.
Maybe you mean the Driver Station doesn't see the cRIO through the router?
There is nothing in the Driver Station that cares one way or another if there is a router in the loop or not.
Unread 14-01-2013, 22:02
inkspell4's Avatar
I believe that would be correct but it sees it when the router is wired to the laptop.
Unread 14-01-2013, 22:07
So the DS connects to the cRIO if you wire it to the router, but not if you try wirelessly.
When you set the router up with the FRC Bridge Config Utility did you give it a WPA?
Using a browser, can you browse to 10.39.88.1? (try both wired and wireless)
Unread 14-01-2013, 22:08
inkspell4's Avatar
I will try tomarrow
Unread 14-01-2013, 22:09
inkspell4's Avatar
Any other things i could attempt
Unread 14-01-2013, 22:11
Dinoyan Dinoyan is offline
Team Role: Electrical
Dinoyan is an unknown quantity at this point
Try to restart the router maybe that will work
Unread 14-01-2013, 22:17
Since just the wireless is a problem there are a couple of things you can check.
  1. First run the FRC Bridge Config Utility again, but leave the WPA field blank this time.
  2. Make sure your laptop IPs are:
    • Local Area Connection: 10.39.88.5
    • Wireless connection: 10.39.88.9
  3. You'll have to tell your laptop to connect to the wireless router
  4. Open a browser and try browsing to http://10.39.88.1 wirelessly first
  5. If that works then your Driver Station should too.
  6. If that doesn't work then use an Ethernet cable and try browsing again.
  7. If you can connect to the router, login: admin/admin and go to the wireless settings and see what they are.
    1. SSID
    2. IP
    3. Netmask
    4. Frequency
    5. 20MHz
    6. Security
