Go to Post Meanwhile, it's water over the dam, spilled milk, etc. Let's drop the subject and get on with life. I am seeing people warming up their lawyerism, which is not a good thing when we are coming up on build season. - EricH [more]
Unread 16-01-2013, 17:17
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Arrowhead is an unknown quantity at this point
Talon Motors
How do you declare talon motors in a program?
I looked around but couldn't find any info on this.
Unread 16-01-2013, 17:42
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Wink Re: Talon Motors
You just declare them like as with victors and jaguars- They use the same PWM signal.
Jaguar *motora;
motora = new Jaguar(1);
Basically, you do not need to code any differently for Victors, Jaguars, or Talons.
Unread 16-01-2013, 17:57
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Talon Motors
In Java there is a Talon Class, there isn't a similar one under C++?
The Java implementation has different max,min, and deadband values for each of the motor controller used for generating the PWM signal.
So while, interchanging them may work, it may not be completely correct, at least on the Java side.
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 16-01-2013, 18:07
Re: Talon Motors
Yes there is.
If you use the Jaguar class with a Talon (and don't calibrate the Talon), you will end up with reduced range.
Unread 16-01-2013, 18:10
AKA: Daniel Brown
Re: Talon Motors
Jaguar *motora;
Ok, thanks for the info
All of the programmers on our team are completely new to FRC, so we are still learning a lot.
Unread 17-01-2013, 09:27
Thaddeus Maximus
AKA: Thad Hughes
Exclamation Re: Talon Motors
Actually, looking at the other people's posts, and realizing there actually is a Talon class in C++ (How did I miss that...) you might want to use the Talon class. Basically just substitute "Talon" for "Jaguar" for declaration and initialization, and everything else is the same.
Unread 17-01-2013, 11:26
Doron_Sivan Doron_Sivan is offline
FRC #4590 (GreenBlitz)
Doron_Sivan is an unknown quantity at this point
Re: Talon Motors
You can declare a Talon in C++ by writing
Talon t1 = new Talon(TALON_PORT);
when TALON_PORT is an int for the port.
Beaware that the RobotDrive class automatically initiallize jaguars when declaring the defult constructor (when the parameters are numbers).
So when you use Talons don't decalre it like this:
RobotDrive drive = new RobotDrive(1, 2, 3, 4);
but like this
RobotDrive drive = new RobotDrive(new Talon(1), new Talon(2), new Talon(3), new Talon(4));
Doron
Unread 18-01-2013, 16:25
AKA: Daniel Brown
Re: Talon Motors
Also, is the min/max values for the talons the same as jaguars?
If not, what are the min/max values?
Unread 18-01-2013, 21:43
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Talon Motors
They're the same. -1 to 1.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 18-01-2013, 21:55
AKA: Daniel Brown
Re: Talon Motors
Ok, thanks
Unread 18-01-2013, 22:55
Re: Talon Motors
FWIW, under the hood they are not the same. Jag and Talon expect different min/max pulse widths.
That's why WPILib provides separate drivers for them.
Unread 18-01-2013, 22:56
AKA: Daniel Brown
Re: Talon Motors
but on the programming side they are the same?
Unread 18-01-2013, 22:57
Re: Talon Motors
The purpose of the separate drivers is to present a common interface to the programmer.
