Go to Post I worship whoever cleans the robotics room. - John Gutmann [more]
Unread 18-01-2013, 15:40
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
[Strategy and design] Robots made to climb up the corner
This is a quick sketch-up of a robot I thought up a while back, designed to go up the ramp via the corner pole. The robot simply drives into the pole and the angle in the front pushes it up the pole to initially leave the ground in the front, while the back wheels keep pushing. Therefore you completely get into position by doing nothing more than just driving forward.
As for how to climb up, after REACHING that position, I have yet to come up with anything. But I just wanted to share an idea I had and make a thread for anyone else thinking of anything else like this
Name:	bot front.jpg
ID:	13562  Click image for larger version
ID:	13563  Click image for larger version
ID:	13564  Click image for larger version
Unread 18-01-2013, 16:15
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: [Strategy and design] Robots made to climb up the corner
We had considered something similar until recently. If you work out the mechanics of driving into the 60deg leg of the pyramid you'll find that you need a large portion of your weight on the rear wheels (70%) and get nearly perfect traction out of the rear drive wheels (0.9-1.0 coefficient of friction without any slippage). These numbers can be massaged based on design, but to me it seems VERY difficult to deal with.
I don't want to discourage you from attempting a design like this, it has merits, but it would pay to carefully work out traction and force requirements before you totally commit to it.
Unread 18-01-2013, 16:20
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Our initial approach is similar. The only thing is, with the position of our bumper and rear wheels, the bumper or frame will start dragging on the floor before the robot reaches the 60 degree angle of the pole. So, the lifting mechanism must take over from there, allowing for the mismatched angle. Still, it's a lot closer than staying on the floor, so the lifter doesn't need to handle as much of an angle difference.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 18-01-2013, 20:22
mbushroe mbushroe is offline
FRC #2840
mbushroe is an unknown quantity at this point
We looked at that design with one or two conveyor belts of magnets to continue the drive up the corner. Remember that when you reach the top, your robot will be facing 60 degrees upward, and the shooter you have drawn will face almost perfectly straight up, not towards the pyramid goal!
Mike
