Go to Post Students learn from, are inspired by, and emulate their mentors. A team with a solid mentor base helps to create a productive, inspired, and ultimately successful group of students. - Jared Russell [more]
Unread 19-01-2013, 07:07
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
Attaching things to belt
Anyone know an effective way to attach sheet metal to a belt [standard kitbot belt]?
The belt would need to go all the way around the pulley.
I was thinking we sew it on? Or superglue it?
Unread 19-01-2013, 09:10
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: Attaching things to belt
Good luck sewing through kevlar reinforced belts, and super glue will probably rip right out. There's a thread somewhere on here recently that asked the same question. They weRe referred to using some chains and special links
Academic Student (Forever)
Unread 19-01-2013, 09:56
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
http://www.mcmaster.com/#roller-chain-attachments/
with roller chain will be much easier than trying to attach things to belts.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2013, 11:59
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Actually, I think those two things can be made to work, though it will depend on the exact application and the thing being attached.
With a commercial sewing machine (like an upholstery machine), you can probably pierce thin aluminum sheet metal (less than 0.020 in) and sew it right through the belt. (You can also pre-punch thicker metal.) You can probably find Kevlar or Spectra thread.
Also, several types of belts are designed to be welded with a high quality ethyl cyanoacrylate superglue (Loctite 404, for example), which may also bond adequately to metal. Watch out for flexing the joint too much, though. Even if the glue survives, you may overstress the substrate.
In both cases, to get it to go around a pulley, you may have to attach it with a single line across the width of the belt. Carefully consider the engineering of this system, because it sounds like it's inherently kind of fragile. Chain may ultimately be easier: see here for more ideas about attachment chain.
Unread 19-01-2013, 12:08
d.kho's Avatar
d.kho d.kho is offline
AKA: Daniel Kho
FRC #2473 (CHSR)
d.kho is an unknown quantity at this point
We're using the chain too, but duct tape works really well in a pinch with the belts. Since when did it not? (We've actually tried it.)
