Go to Post Someone Photoshopping Heidi...............now there's a switch! - Jay H 237 [more]
Unread 20-01-2013, 18:47
cRIOandMilk cRIOandMilk is offline
FRC #0649
cRIOandMilk is an unknown quantity at this point
Changing shooter angle?
Is anyone planning on tilting your shooter to change the angle? How are you planning to do that in combination with your storage/hopper?
We are currently hung up on transporting our frisbees to the shooter and having them enter the shooter at the shooter's angle.
Unread 20-01-2013, 18:53
Andrew Lawrence
Posts: n/a
Re: Changing shooter angle?
Our linear shooter will be able to change its angle vertically. Our frisbees will enter the shooter at the height parallel to the shooter when it's horizontal. When the shooter angles up, the frisbees will simple fall into place.
Unread 20-01-2013, 19:16
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're building one assembly, the hopper is above the shooter, they'll both move together. The current plan is to see if we can get away with one angle for shooting, the other for driving under the pyramid/hanging at the end of the match. The hanging stuff will be integrated with the hopper/shooter assembly.
Unread 20-01-2013, 20:27
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
This is something we're still trying to test. One thing that we want to see is if we need to change shooter angle, or if reducing the speed enough will allow variations in peak height.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 20-01-2013, 20:59
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We're planning for two positions right now. One position for autonomous/close shots, and one for long-range shots across the field.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 21-01-2013, 10:43
MrBydlon's Avatar
MrBydlon MrBydlon is offline
AKA: Jeremy Bydlon
FRC #3313 (Mechatronics)
MrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud of
We are planning on doing this! Check out our prototype robot playlist for our idea. See the "Pneumatic Piston" or "Hanging Idea" to see what we thought up.
http://www.youtube.com/playlist?list...ANL0nXDlcM_1GF
Head Coach
FRC Team 3313 Mechatronics
Alexandria, MN
2014 10,000 Lakes: Chairman's Award Winner
2014 10,000 Lakes: Winner with 2052 and 2227
2014 Lake Superior: Finalist and Engineering Excellence
Website Twitter Facebook YouTube
Unread 21-01-2013, 11:30
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
We're hopefully going to! We just have to work on the cad for it.
Off to WPI!
Go OxBE4
Unread 21-01-2013, 11:35
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We're planning on at least a default and a steep angle. Depending on how well the vision system works, we'll have full control from ~10 degrees to ~45 degrees. We've designed in a 9015 or RS-540 through a gearbox to an acme screw. If we wind up only needing 2 angles, we'll swap in a small-bore pneumatic cylinder. Similar to what others have posted, the storage device tilts with the variable angle.
GitHub
Unread 21-01-2013, 11:38
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Thumbs up Re: Changing shooter angle?
That was really good for just a prototype robot! Was that pneumatic cylinder the kind that just goes all the way in or out; or was it the kind that could stop at any point you wanted it to? It looked strange to me the way it went up just a little bit then stopped... Or was it just out of air?
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 21-01-2013, 11:44
MrBydlon's Avatar
AKA: Jeremy Bydlon
We have a 3 way (don't know the exact name) solenoid valve that allows us to stop the piston at any point. Still follows all pneumatic rules that we are aware of. Extremely handy.
Head Coach
Alexandria, MN
