Go to Post I think these new rules are making the message coming from FIRST perfectly clear - engineering is about what happens between your ears, not what comes out of your deep pockets. - KenWittlief [more]
Unread 21-01-2013, 19:23
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Command-based while button presed
I want to run a specific command but i only want to run it when the button is pressed but i cant find the specific function for that
            OI.controlDriver.buttonA.whenPressed(RobotMap.intakeIn);
            OI.controlDriver.buttonA.whenReleased(RobotMap.intakeIn);
            OI.controlDriver.buttonB.whileHeld(RobotMap.intakeOut);
they just continually run the command
Unread 21-01-2013, 19:34
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Command-based while button presed
The problem isn't in the button call itself. You need to set the isFinished() method in your command to something other than "false," otherwise it will never complete.
Psuedocode:
isFinished() {
      when (frisbeeIsLoaded)
              return true;
or
isFinished() {
       return isTimedOut();
When isFinished() returns true, it calls end() and stops the command. If it never returns true, end() is never called.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 21-01-2013, 19:44
Mastonevich's Avatar
Mastonevich Mastonevich is offline
Andrew
AKA: Andrew Elsen
FRC #1987 (BroncoBots)
Mastonevich is a jewel in the roughMastonevich is a jewel in the roughMastonevich is a jewel in the rough
We found somewhere in the documentation where u need to put it in the interrupted function and it worked for us.
~Andrew
Regional Chairman's: 2013-Alamo, 2010-Oklahoma, 2009-Colorado
Engineering Inspiration: 2016-Hub City, 2012-St. Louis, 2008-Minnesota
Regional Wins: 2010-Oklahoma
Unread 21-01-2013, 20:03
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Yeah.... was about to say that putting the cancel functions in interrupted and not end worked.
On a slightly related topic, can I wipe the commands currently linked to a button?
i can do
button.whilePressed();
but can i do
button.releaseCommands();
so that it no longer runs the commands issued by .whilePressed()
