pic: FRC 3184's drop test results 2
Re: pic: FRC 3184's drop test results 2
How was the frame put together?
It used the Press Fit Framing system from McMaster
Tubes are P/N 47045T48 Connectors are P/N 47045T81 - 47045T86 |
Another reason our team didn't choose to climb to 30. The sacrifice of the frame was worth it to prove the damage.
Go Orange Alliance! |
I would be interested to see results with a bolted/rivited/welded/sheetmetal frame. As most teams won't be using the system you mentioned, these tests are of limited utility to the community.
Like everyone else said, don't fall. |
weighted in down to 155lbs. Lifted it to 7.5ft off the ground...
what did it do to the floor? |
#7
Our big thick concrete floor survived with little more than a scuff where the robot impacted.
#8
We use a similar connector from a different vendor, I wonder what it would have looked like had the connectors been pinned to the extrusion instead of just pressed in.
#9
Some of the connectors appear to have sheared in the other picture, so it doesn't seem like press fitting vs screw/pin fitting would make a difference.
