Go to Post Patience is the key to FIRST. - Pavan Dave [more]
Unread 23-01-2013, 14:04
Vin Vin is offline
AKA: Neil
FRC #4024 (The Jokers)
Vin is an unknown quantity at this point
Dimensions clarification
Hi,
We have some confusing opinions on this, so hoping someone here can help clarify: Is it acceptable for a robot to be sized such that it meets the 112" perimeter limit up to 10" above the ground (ie: within the bumper zone), but have a larger perimeter above that height? So it would look like a large box placed on top of a smaller box that has a 112" perimeter. Yes, the whole robot would fit within a 54"-dia, 60"-high cylinder.
Thanks.
Unread 23-01-2013, 14:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Dimensions clarification
Originally Posted by Vin View Post
Hi,
Thanks.
No, if it starts that way. Yes if it expands out to those dimensions (subject to the 54" diameter rule) after the start of the match.
Originally Posted by R04
In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
R02 Defines what a FRAME PERIMETER is, R03 limits the FRAME PERIMETER total length.
GitHub
Unread 23-01-2013, 14:11
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
As I understand the rules, in a starting configuration all robot parts must be with the frame perimeter.
Unread 23-01-2013, 15:40
DonRotolo's Avatar
Back to humble
FRC #0832
Hi,
Thanks.
No, this would not be legal.
Unread 23-01-2013, 22:53
Vin Vin is offline
AKA: Neil
Ah yes. Not a big deal though.
Thanks.
