Go to Post Things are not always as simple as they seem. - Paul Copioli [more]
Unread 23-01-2013, 21:56
TheGuyz TheGuyz is offline
FRC #2443
TheGuyz is an unknown quantity at this point
Corner bracket
What level is the corner bracket that connects the horizontal bar to the vertical leg of the pyramid counted as?
Unread 23-01-2013, 22:12
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: Corner bracket
Does this answer your question?
Unread 23-01-2013, 22:21
FRC #2443
I just want to make sure that the bracket is part of the lower level. The picture shows that it is. But I just want confirmation.
Unread 23-01-2013, 22:31
WileyB-J's Avatar
FRC #4976 (Rebels)
Re: Corner bracket
Here's a question (that I believe is what you're asking) from the Official Q&A:
In the Q&A
Follow that for an official answer.
Cheers
Unread 23-01-2013, 22:45
FRC #2443
So, do you know if the corner bracket is part of the lower level or higher level?
Unread 24-01-2013, 00:26
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Corner bracket
It should be clear from the drawing, but the bracket is below the top surface of the horizontal rung, so it is at the same level as the horizontal rung it is holding.
I don't get why the zone borders are so misunderstood. Any metal below the plane tangent to the tops of the first rung is in level 1. Any metal below the plane that sits on top of the second rung (and is not part of level 1) is part of level 2. All remaining metal in the pyramid is part of level 3.
Hope this helps.
